Headlight internals
Old Dec 21, 2014 | 05:48 PM
frostedmax2011's Avatar
Headlight internals
I have a 2011 maxima S w/ Halogen headlight assemblies. I came across a set of 2010 HID Headlight assemblies. The housings themselves are damaged but all internals (bulbs, ballasts, wiring) are fine. My question is can i disassemble the HID headlight assemblies and swap the internals (bulbs, ballasts, bulb socket, etc.) into the standard halogen assemblies? Is there a difference in headlight wiring harnesses? Thanks.
Old Dec 22, 2014 | 01:03 PM
Grego214's Avatar
HID assemblies have an opening at the bottom of the light where the OEM ballasts go, the halogen does not. Also the projector on the HID assembly is different than the halogen as well as the cut off shield on the inside.
If you want to swap the plastic bezel and trim pieces from light to light, thats fine. Even the clear plastic cover you could swap. I would just buy another halogen set.
If you are looking to upgrade the halogen set, you could swap the shields from an HID set or buy them on Theretrofitsource. You can also buy the black series clear lens and an HID kit from there as well. You will notice a great difference coming from halogen lights.
Old Dec 22, 2014 | 02:08 PM
Thanks grego. I was hoping it would be as easy as swapping all components from the HID set into the Halogen Housing, oh well. How bout the harnesses? all wiring the same?
Old Dec 22, 2014 | 02:39 PM
Grego214's Avatar
Originally Posted by frostedmax2011
Thanks grego. How bout the harnesses? all wiring the same?
Everything is the same, turn signal, side marker, high beam.
The difference is the low beam because the HID lights projector you mount the bulb inside the headlight to the projector with two fasteners. Then the OEM ballast connects onto the back of that and runs out the bottom of the headlight to the hole I mentioned. From there the ballast is screwed to the bottom of headlight to close that hole.
Old Dec 22, 2014 | 02:44 PM
Gotcha Thanks
Old Jan 14, 2015 | 04:45 PM
Stooop32's Avatar
Is there a substantial difference between stock HIDs and halogens with a quality HID conversation kit? Obviously going from halogen to HID is a dramatic difference either way, but would it be worth a couple hundred dollars more to get a complete OEM HID assembly?
Old Jan 15, 2015 | 11:39 AM
Grego214's Avatar
What you could do is just buy the Maxima HID projectors taht come in the OEM HID lights, swap them into the halogen lights, get an aftermarket hid kit and the black series clear lens from Theretrofitsource and you will have an amazing result.
Old Jan 16, 2015 | 05:25 AM
escblads's Avatar
Yup, and they're $60 for the pair right now, but they're not always available since these are the closeout items.
http://www.theretrofitsource.com/clo...trsdefaultview
And the black series clear lens (HIGHLY RECOMMENDED)
http://www.theretrofitsource.com/com...lear-lens.html
Old Jan 17, 2015 | 12:42 PM
Stooop32's Avatar
This may be a stupid question, but aren't OEM halogen and OEM HID assemblies interchangeable? I'm not sure what plugs into the factory ballasts but would think that you could plug and play swap the whole assemblies?
Old Jan 17, 2015 | 08:10 PM
ThinBlue82's Avatar
No, they are different.
Old Jan 21, 2015 | 08:41 AM
Grego214's Avatar
Read the replies in the above thread and you will have your questions answered.
Old Jan 21, 2015 | 09:25 AM
saltohio's Avatar
Originally Posted by And the black series clear lens (HIGHLY RECOMMENDED)
[url
http://www.theretrofitsource.com/components/lenses/morimoto-black-series-clear-lens.html[/url]
I upgraded with Morimoto XB35's (6000K) and would like to do these lenses as well. However I'm tentative about "baking" the headlights. Is there a comprehensive how-to somewhere? "baking" is used to gain entry into the housing, correct?
Old Jan 21, 2015 | 09:56 AM
Grego214's Avatar
Below is a link to a thorough walk thru made by Ghozt aka Dan. Its fairly simple to bake them open and then once your have them open, the projector is held on by 4 screws. Remove those then take the projector out. The lens bracket is held on by 3 or 4 screws and you take that off. After that, you need to press in on the 3 tabs holding the lens in. Be careful not too put too much pressure on it or else they will break. Once you have the lens out, the black series lens should pop in. If it doesn't completely fit (it should) then you will need to add a spacer that TRS provides when buying.
http://my7thgen.org/f57/how-bake-ope...-headlight-69/
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
