U joint question
Old Feb 15, 2015 | 11:29 AM
speechguy123's Avatar
U joint question
I have a 2009 SV maxima with almost 100K on it.
I have a feeling the U joints need to be replaced.
Does anyone know if this can be done without replacing the entire drive shaft as well?
Old Feb 15, 2015 | 11:34 AM
chrome91's Avatar
U-joints are on the driveshaft of RWD and AWD vehicles
if youre referring to the CV joint/axle then yes you basically have to replace the whole axle
Old Feb 15, 2015 | 12:25 PM
george__'s Avatar
What's a u joint?
Old Feb 15, 2015 | 12:27 PM
Fakie J Farkerton's Avatar
Originally Posted by chrome91
U-joints are on the driveshaft of RWD and AWD vehicles if youre referring to the CV joint/axle then yes you basically have to replace the whole axle
Old Feb 15, 2015 | 12:32 PM
CS_AR's Avatar
Originally Posted by george__
What's a u joint?
Answer:
Old Feb 15, 2015 | 01:39 PM
chrome91's Avatar
What's a u joint?
its on the driveshaft to allow it to change angles and bend while still being able to transfer motion
Old Feb 15, 2015 | 06:12 PM
Boxness's Avatar
Just to actually answer for you. Your max doesn't have u-joints you'll have cv axles. To change them you'll replace the whole shaft. But there's no need to unless you actually have an issue with the joint. We don't even replace them for a split boot. We'll regrease them and install a new boot. Unless there's a defect there's no reason to replace them just sure to mileage.
Old Feb 16, 2015 | 06:51 AM
CanadianMoFo's Avatar
Actually there are a couple U-joints. They're in the steering column shaft.
Old Feb 17, 2015 | 04:55 AM
LtLeary's Avatar
I have a 2009 SV maxima with almost 100K on it. I have a feeling the U joints need to be replaced. Does anyone know if this can be done without replacing the entire drive shaft as well?
It took me less than an hour when I replaced my passenger side axle assy. If I recall correctly, less than 100 from rockauto!
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
