Eibach Spring Question
Old Mar 31, 2015 | 01:40 PM
SC-Upsate_SV's Avatar
Getting ready to order the Eibach kit for my car. Is the camber kit a must have with this kit? Thanks in advance.
Old Mar 31, 2015 | 02:44 PM
lexcitement's Avatar
Camber Kit
To answer your question, the drop is not that drastic that you would need a camber kit. Nice drop nonetheless but don't need it.
Old Mar 31, 2015 | 02:59 PM
MaximaDrvr's Avatar
Some need it and some don't. I needed the camber kit and 350Z rear control arms to get my alignment in spec.
Old Mar 31, 2015 | 04:32 PM
Tommy6905's Avatar
This exactly, I think if spacers are used its an absolute necessity
Old Apr 1, 2015 | 02:46 PM
1996blackmax's Avatar
Same here.... My car ended up needing it.
Old Apr 1, 2015 | 08:42 PM
Lambo's Avatar
Lowered on Eibachs n oem19s didn't need alignment. Added 22"s to the Mix and needed one and did an aligned with 22"s took 22"s off and back on oem 19"s and spacers. Don't need alignment
Old Apr 2, 2015 | 09:14 AM
How did you determine that you didn't need an alignment? Did you get the alignment checked after installing the spring?
Old Apr 2, 2015 | 11:33 AM
fame126's Avatar
guaranteed if you took it to a shop that measures your camber and toe and thrust angle you would be out of spec if you're thinking just because it doesn't pull one way or the other it's out of alignment you couldn't be more wrong
Old Apr 2, 2015 | 11:42 AM
Tee00Max's Avatar
I say get the springs installed and find the best alignment shop that's close to you (After you let the springs settle all the way in). See how close they can get it in spec and if its not that far off then just roll with it. I know on my 2010 w/18's I need the camber kit and now with my 2013 w/19s I don't so its just a kind of hit and miss and also how well the alignment shop does. Take a picture of the alignment numbers after you get it done and go from there.
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 13, 2015 09:32 PM
Johnny9595
Sep 3, 2015 05:18 AM
