Brake light and hard acceleration
Old Apr 20, 2015 | 06:17 PM
fame126's Avatar
Noticed this happened a couple times, as I was getting on it I saw that in my rpm gauge my brake light comes on and when I let off gas it goes away. Any ideas?
Old Apr 20, 2015 | 06:50 PM
Richard66's Avatar
Check your brake fluid level, it's probably a little low.
Old Apr 20, 2015 | 09:54 PM
1996blackmax's Avatar
Yup, thinking the same thing.
Old Apr 20, 2015 | 11:28 PM
ThinBlue82's Avatar
Agree with the above. If it's low then you either have a leak (doubtful) or it's time for new brake pads. Adding fluid is the quick fix for the light coming on but more than likely you'll need a brake job.
Old Apr 21, 2015 | 09:47 PM
CorollaULEV's Avatar
AND depending on how hard you are on the brakes, check rear ones first. Oddly, with these cars, rears wear out fastest. Replaced rear on my 2010 at around 70,000mi and fronts were replaced at about 130,000mi (even thought they would have lasted another 10,000mi easy). Just FYI...
Old Apr 22, 2015 | 03:59 PM
fame126's Avatar
It's under hard acceleration not braking though. Does that make a difference?
Old Apr 22, 2015 | 05:29 PM
Richard66's Avatar
No because both will tilt the brake fluid reservoir just enough to uncover the low warning sensor if the reservoir is low on fluid.
Old Apr 22, 2015 | 05:31 PM
fame126's Avatar
Thanks for the reply much appreciated
tsi6001
Oct 3, 2022 10:23 PM
305head
Aug 26, 2015 09:03 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
