LED Load Resistors?
Old Apr 22, 2015 | 07:09 AM
slatemaxima's Avatar
Unhappy LED Load Resistors?
Hi Guys,
I'm sorry if this is a duplicate thread, but I couldn't find the specific answer I was looking for anywhere in the forum. So here goes...I am installing switchback LEDs in the front turn signals and Red LEDs in the rear turn signals. I know that I will require load resistors but I am unsure as to how many and which ones I would need. From what I searched, I found that if I am doing just the rears or the fronts, I can use 50W 6OHM resistors and if I am doing all 4, I can use (2) 3OHM resistors. Problem is, I can't seem to find 3OHM resistors from reputable sites. Now my question is, can I just use (4) 50W 6OHM resistors connected to each bulb? Thanks in advance and sorry if this topic has been covered elsewhere, I was just unable to find it.
Old Apr 22, 2015 | 01:04 PM
Lambo's Avatar
JLC 50W 3Ohm LED Load Resistors for LED Turn Signal or LED License Plate Lights - Fix Hyper Flash, Warning Notices https://www.amazon.com/dp/B00AR12X4I/ref=cm_sw_r_awd_f5.nvb1HVWVY9
Bought these and they came in today. Haven't had the time to install yet will report back once hooked. For the record I have led switchback turn signals up front and Amber led turn signals in the rear. And bought one pair of 3ohm load resistors. If they won't work gonna return to amaon
Old Apr 22, 2015 | 01:07 PM
javzbumpz's Avatar
If you're running LEDs in just the front or the rear then 2 - 6 ohm resistors installed where the LEDs are is all you need. If you're doing the front and backs you needs 4 - 3 ohm resistors, one installed at every LED. I found 3 ohm resistors on ebay for 3 dollars each.
Old Aug 20, 2015 | 11:35 AM
Devits's Avatar
Help with tapping
Hey guys, do you know which 2 wires on my 7th gen front turn signals i need to tap? I included 2 pics below of each side. Thanks, Drew
Old Sep 29, 2015 | 02:31 PM
trsandrew's Avatar
Former Sponsor
Just grab a voltmeter and find out which is your parking light (constant), and which is switched (turn signal). That's the best sure-fire way!
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
