Front passenger full range speaker not working!
Hey people, has anyone had a problem with their speakers going out, particularly the front? How do you replace the corner ones? I found the speakers online, but no info on how to replace them? I'd hate to think that the dash would need to be removed to get to a speaker or how much that may cost! Any insight would be greatfully appreciated.
They are pretty easy to get to. Pull off the A-pillar covers, then you pull the grills off. The A-pillar covers hold them down in the corners. After that the speakers are accessible.
Just get a set of coaxials....they will be cheaper than the OEM drivers & will sound better.
Factory is 2 ohm...In the past JBL & Infinity made 2 ohm drivers. Some of their newer speakers are 3 ohms & they will work out fine. I actually ran a set of 4 ohm Boston coaxials for a while.
Yup...efficiency also plays a role as well. I recently switched out the Audison Voce 3.0 mids I had for set of Vifa's. There was a very noticeable difference in volume as the Voces are more efficient. They are both 4 ohm drivers.
Also, you may want to reinstall the rubber moulding while you are working so that it doesn't get in your way & pull it off before putting the pillar covers back on.
carguy96
20
Feb 6, 2021 06:21 AM
trasmadean
Feb 1, 2017 08:20 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
