Wiring DRLs on 13 Maxima
Old Jul 16, 2015 | 05:29 PM
kristitties's Avatar
Hey guys,
Although I've done other modifications to the body, I've never done any wiring.. so I guess I just need a walk through on how to make sure im doing this right. Im trying to install LED daytime running lights. I just don't want to mess anything up. Besides the actual lights, what do I need? relay, switch, harness? and specifically what kind..
Thanks!
Old Jul 16, 2015 | 07:32 PM
funnyman82's Avatar
Depends on how you want to wire it really.
Option 1: use an add a fuse in the windshield motor fuse under the hood and then run a switch into the car for independent control of the drl and not having any other lights on if desired
Option 2: do the same as option 1 but Use a wireless box with remote so no need to run wires inside for independent control of the drl and not having any other lights on if desired
Option 3: splice into the park light wires so they run with them, so they only run with the park light
Old Jul 17, 2015 | 05:28 AM
saltohio's Avatar
Another option would be to have them on at all times the car is on.
Old Jul 17, 2015 | 05:41 AM
mikekay's Avatar
don't you want them off when the headlights turn on though? I turn my lights on even during the day -- and fogs -- I just like being more visible.
Old Jul 17, 2015 | 05:51 AM
VVhite-0ut's Avatar
Do you just add a fuse to that area? 'windshield motor'? And how does the switch connect to just that fuse? That's what has me confused. I'd imagine the switch has a line to the fuse and a line to the battery? And the drl would have a line to switch and line to battery?
Old Jul 17, 2015 | 06:10 AM
mikekay's Avatar
Wouldn't add-a-circuit be the best way? and tap into something that turns off in drive ie parking brakes?
Old Jul 17, 2015 | 10:13 AM
Daaavid's Avatar
The safest route that will turn on and off with the car is to use an add-afuse with a 15A fuse tapped into the fuel pump through the engine bay fuse box.
Old Jul 17, 2015 | 11:24 AM
VVhite-0ut's Avatar
What is the proper name for this 'add-afuse' and can it be purchased at an autozone? I've never messed with wiring before so please excuse my stupidity. So when I buy a set of DRL's, I just hook them up to the 'add-afuse' add the extra fuse and that's it?
Old Jul 17, 2015 | 03:08 PM
Ross2893's Avatar
I have switchbacks and I just spliced them into my Park lights for the drl and the turn signal for the switchback function
Old Jul 17, 2015 | 07:51 PM
funnyman82's Avatar
Add a fuse...Add a circuit....Same thing..
Here is a link to one. Make sure u get the micro fuse as that is what the maxima uses:
http://www.amazon.com/CT-Profile-circuit-Adapter-Circuit/dp/B0016LWQLS
Maxilano
Aug 31, 2015 07:33 PM
spidgeon
Aug 18, 2015 05:46 AM
maximaham
Aug 7, 2015 01:11 PM
Blackwind
Aug 5, 2015 06:35 PM
bassmann
Aug 3, 2015 07:53 PM
