Want to install Fog Lights in my S Model
Old Oct 11, 2015 | 09:16 PM
gman214's Avatar
Looking to install fog lights in my S. What's involved? Will I need to install a switch on steering wheel or dash?
Old Oct 12, 2015 | 05:07 AM
REDinLV's Avatar
If going for OEM...The fog light switch is on the turn signal switch like here. It's the inner most barrel on the switch. Headlight barrel -> Indicator line -> Fog light barrel
Old Oct 18, 2015 | 04:48 PM
Maxgig's Avatar
Your car may already be wired for fog lights. Check behind the front bumper for the wiring loom. If it is all you'd have to do is get the lights, and put in the proper size fuse.
If its not, going OEM is too complicated a job, (at least for my skill level). I would recommend you get the lights you want, install them and mount a separate toggle switch under the dash.
Old Oct 18, 2015 | 05:09 PM
REDinLV's Avatar
^^^This. By far the easiest. There should be plenty of open slots in the dash where you could add a nice toggle switch. Check near where your left knee would be.
Old Oct 19, 2015 | 02:03 AM
njjfudge's Avatar
I installed a factory kit in my S a couple months ago and it was simple. No wiring just changing out the switch on the column and installing the lights, took around an hour because I tried to install the fogs without dropping the bumper then realized I needed to.
Old Oct 21, 2015 | 05:06 PM
magiconthetire's Avatar
Would you kindly be able to point me in the direction of the parts you used and where you acquired them? Most notably the column switch? Many thanks
Old Oct 21, 2015 | 06:26 PM
Also,
If I purchased new OEM fogs, what all else would I need to complete the conversion? Thank you kindly
Old Oct 22, 2015 | 06:08 PM
Llfe's Avatar
the fog light kit for $218.75 + shipping from courtesyparts.com comes with everything you need for the install. Need to buy the bulbs. I went ahead and bought a HID kit. My 09 S model was prewired for fogs. I would check to make sure the wiring is already there. Installing the column switch was easy. Installing the fog light with the brackets was a pain in the but since I did it w/o removing the front bumper...otherwise, it would have been a lot easier.
kit w/ auto head lamps = http://www.courtesyparts.com/exterio...ps/999f1-a3501
kit w/o auto head lamps = http://www.courtesyparts.com/exterio...ps/999f1-a3502
*just found these for almost 1/4 of the price...no column switch =
Amazon.com: Spyder Auto FL-NM2010-C Nissan Maxima Clear OEM Fog Light: Automotive Amazon.com: Spyder Auto FL-NM2010-C Nissan Maxima Clear OEM Fog Light: Automotive
Old Oct 24, 2015 | 09:24 PM
njjfudge's Avatar
I came across the column switch on e-bay on a deal. I didn't get OEM fogs, I just got a set off e-bay, think I paid less than $130 for everything. The kit from courtesyparts.com is a very good deal because all the parts are OEM. If you have the switch fogs with the bracket and bulbs that should be it, the wiring is already in the car so everything is plug and play.
Old Oct 26, 2015 | 08:21 AM
Llfe's Avatar
you got a really good deal on urs....i wish i could have done what you did and saved 1/2 the $$$
Old Nov 1, 2021 | 01:59 PM
Sandysusana's Avatar
Did you have to add any fuse ? Or just was working roght away?? Thanks
Old Nov 4, 2021 | 04:29 AM
Churchill729's Avatar
I installed OEM fog lamps in about 20 minutes.
All wiring was already there. I just plugged in the new lights.
The new turn signal stalk was not difficult either.
Everything was about $200.
trsandrew
Oct 25, 2015 02:47 PM
06maxima55
Sep 28, 2015 04:29 PM
ToTheMax305
Sep 23, 2015 09:11 PM
followthadollar
Sep 22, 2015 11:53 PM
meccanj98
Sep 17, 2015 08:28 AM
