high idle RPM? (1500~)
Old Oct 28, 2021 | 04:38 PM
vasu94's Avatar
Question high idle RPM? (1500~)
seems weird to have a high idle while in park with no A/C, any easy fixes as to why?
Old Oct 29, 2021 | 11:12 AM
LtLeary's Avatar
Well there are a few reasons that come to mind for a high idle
1.) Vacuum leak
2.) Dirty Throttle Body
3.) No water in the lines to the Throttle Body assy
4.) Idle relearn wasn't performed after some maintenance
All are relative easy fixes although purging the water lines to the throttle body assy can get a little messy.
So, How Many Miles?
Any Maintenance Done?
What year and model?
Any lights on the dash?
Any Codes?
Old Oct 30, 2021 | 09:50 AM
vasu94's Avatar
I've never done any sorr of that kind of maintenance so you're def right in that regard, no lights on the dash, bout to cross 100k so I'm trying to take care as much as possible to keep it going to 200!
Old Oct 31, 2021 | 11:41 AM
Jay-flow's Avatar
Hi I've had the same problem, the solution to mines was the Mas airflow sensor.
Old Nov 2, 2021 | 08:13 AM
andy_el_gato's Avatar
Mines had a vacuum leak at around 105 k miles which led to high RPM. I would check for cracked rubber hoses behind the engine.
Old Nov 4, 2021 | 02:40 PM
vasu94's Avatar
solved! throttle body service by Nissan, cost 150
if you don't service in time, you'll end up needing to change the mas air flow sensor is what the rep told me
Old Nov 4, 2021 | 07:28 PM
mahanddeem's Avatar
Can you please explain what did they do to the throttle body exactly? did they tell you? Was it cleaning it or the reprogramed the idle?
LMaRiE91MaXiMa
Dec 10, 2021 09:02 PM
Grey00lustre
Dec 4, 2002 03:18 PM
asianpr3082
Oct 24, 2001 08:31 PM
Sarah99GXE
Apr 29, 2001 07:30 PM
