Jack Stand Spots
Old Nov 20, 2015 | 02:04 PM
slvrmax420's Avatar
Jack Stand Spots
Where is everyone placing their jack stands under the car? Front and back. Anyone with pictures would be great. Thank you for responses ahead of time.
Old Nov 20, 2015 | 03:07 PM
MaximaDrvr's Avatar
There are notches in the pinch seam at each corner where you can jack the car up.
It also tells you in your owners manual.
Old Nov 20, 2015 | 05:40 PM
Richard66's Avatar
I believe the OP is asking about where you place the jack stand as the assigned jacking point is already taken up by the scissor jack. Is there a flat spot next to the pinch seam with the notches where he could place the jack stand safely then remove the scissor jack.
Old Nov 20, 2015 | 06:44 PM
MaximaDrvr's Avatar
Depends on what I am trying to do.
There are 'frame rails' under the car that can be used near the fron, or you can use where the lower control arm bolts in, or under the control arm itself.
Really any spot near a structural member so suspension component can be used.
slag
Nov 20, 2015 05:32 PM
Skidave
Nov 16, 2015 05:30 PM
jerrod99_se-l
Nov 11, 2015 11:21 PM
