What is the proper socket size?
Old Dec 28, 2015 | 05:44 PM
Jpags's Avatar
What is the proper socket size needed to remove my 19" OEM wheels on my 2014 Maxima SV Sport?
Old Dec 29, 2015 | 05:52 AM
vball_max's Avatar
So the lug nuts? They are 21mm on my stock 18s and i assume the 19s would be the same. You also have the tire iron that you use with the jack int the trunk you could use also. If you have to ask about lug nut size, are you sure you should be doing work on your car?
Old Dec 29, 2015 | 10:19 AM
dmcmahan12's Avatar
^^^^^ Good call!
Old Dec 29, 2015 | 11:12 AM
mikekay's Avatar
Are you talking about the security nut? That can be replaced at Nissan,
The others are a 19mm socket
Old Dec 29, 2015 | 03:15 PM
Jpags's Avatar
I just purchased the 21mm socket for my torque wrench which is the correct size for the nineteens. I just purchased my 2014 Maxima SV Sport/Tech package which was a brand new dealer left over. I've had VWs for many years and have always rotated and changed out the winter tires on my own. My experience with dealers is that they usually over torque the wheels so I prefer to do it myself.
jimr1728
Wheels/Tires
Nov 2, 2015 04:18 PM
Ssilva5231
Nov 2, 2015 10:36 AM
Ssilva5231
Nov 2, 2015 10:27 AM
Kriis Bittola
Oct 27, 2015 04:50 PM
lightsandsirens
Oct 25, 2015 08:11 AM
