Location of EVAP canister vent control valve
Old Apr 6, 2016 | 01:28 PM
morenar's Avatar
I've been getting the P0455 code and have replaced my fuel cap but still smell gas and getting the loose fuel cap warning then a few miles later the Service Engine Soon light comes on and stays lit. I wanted to try and replace the EVAP canister vent control valve and see if that would fix it. I spent some time under the car today and could smell gas and found the EVAP Canister Filter but not the EVAP canister vent control valve. From reading the service manual you have to remove the gas tank. Is that right or is there a easier way to get to the EVAP canister vent control valve? This is a for a 2011 Maxima SV.
Old Apr 7, 2016 | 09:12 AM
Nopike's Avatar
http://www.nicoclub.com/FSM/Maxima/2011%20Maxima/
Old Apr 7, 2016 | 09:51 AM
morenar's Avatar
Thanks, that is the service doc I was looking at for the fuel system but it does not show the location of it in a diagram. It only states that you have to remove the rear stablilizer bar first. Is there anyway to get to it without this?
EVAP CONTROL SYSTEM PRESSURE SENSOR
Removal and Installation INFOID:0000000006732206
REMOVAL
1. Remove rear stabilizer bar clamps and position rear stabilizer bar aside. Refer to RSU-15, "Removal and
Installation".
2. Disconnect EVAP hose from EVAP canister.
3. Disconnect EVAP control system pressure sensor.
4. Remove EVAP control system pressure sensor and O-ring.
CAUTION:
Do not reuse O-ring.
INSTALLATION
Installation is in the reverse order of removal.
CAUTION:
Ricky Green
Feb 9, 2017 04:33 PM
Rubossin
Mar 30, 2016 08:35 PM
johnpro
Jan 29, 2016 04:18 PM
Hurricane05
Jan 26, 2016 09:24 AM
MiaRaider81
Jan 13, 2016 04:00 AM
