Brake pads need replacing?
Old Apr 18, 2016 | 11:46 AM
EndoT800's Avatar
I took my car in for a brake fluid flush recently and the mechanic stated that my pads may need replacing as he estimated that i had 15% remaining so I ordered the Akebono pads for the front & rear. After looking at the pads a bit closer, it seems that I have more like 50% remaining in front & maybe 40% rear. I took some photos, but what do you guys think. They still work great but I don't think there at the point of replacing just yet.
Front Pads
Rear Pads
From the service manual
Front Disc Brake
Unit: mm (in)
Brake model Kiriu
Wheel size 457 (18) 483 (19)
Brake pad
Standard thickness (new) 11.0 (0.433)
Repair limit thickness 2.0 (0.079)
Disc rotor
Standard thickness (new) 28.0 (1.102)
Repair limit thickness 26.0 (1.024)
Thickness variation (measured at 8 positions) 0.015 (0.0006)
Maximum runout (with it attached to the vehicle) 0.035 (0.0014)
Rear Disc Brake
Unit: mm (in)
Brake model Kiriu
Brake pad
Standard thickness (new) 8.5 (0.335)
Repair limit thickness 1.0 (0.039)
Disc rotor
Standard thickness (new) 16.0 (0.630)
Repair limit thickness 14.0 (0.551)
Maximum runout (with it attached to the vehicle) 0.05 (0.002)
What I did find alarming was this inner sidewall crack which means I need new 19in rubber.
Old Apr 18, 2016 | 05:47 PM
MaximaDrvr's Avatar
Fronts are fine. Rears are ok, but I would say 30%ish mostly because you don't wear pads all the way to the backer.
Old Apr 18, 2016 | 06:10 PM
zoemayne's Avatar
that tire looks dry rotted... so you either have 2 or 4 dry rotted tires.
Old Apr 19, 2016 | 05:34 AM
14blackbeauty's Avatar
yes, you need tires
Old Apr 19, 2016 | 10:34 AM
fame126's Avatar
What did they charge you for a flush? And where are you located?
Old Apr 19, 2016 | 02:45 PM
maxud's Avatar
Those pads are nearly new and you can wear them down to 2mm without any concern. Typical b/s from the ripoff shop. One thing to make sure is to check both left and right calipers and within caliper both inner and outer pad. You can always find one pad that is sticking and worn way more than others. In which case that indicates an issue with hardware and needs addressing.
Old Apr 20, 2016 | 10:44 AM
EndoT800's Avatar
Originally Posted by 14blackbeauty
yes, you need tires
I'm looking to get these next week. I'm in SoCal so I never have contact with snow, just some rain during winter plus they have a $70 Prepaid Visa card offer.
http://www.tirerack.com/tires/tires....cleSearch=true
BRIDGESTONE POTENZA RE970AS POLE POSITION
Ultra High Performance All-Season
Load Range: XL
Serv. Desc: 98W
UTQG: 400 AA A
Old Apr 20, 2016 | 01:20 PM
dmcmahan12's Avatar
You can get a better tire at a lower cost then the Bridgestones. Just saying. do a little research on here for tires and see what most people run. Good luck with your tire purchase.
5thgendriver
Mar 3, 2016 06:35 PM
Texakinz
Mar 1, 2016 04:04 PM
Ray229Harris
Feb 26, 2016 08:42 AM
sebastian2041
Feb 18, 2016 07:16 AM
ColdCananda
Feb 16, 2016 03:47 PM
