a little bog at a stoplight with A/C on.
Old May 10, 2016 | 10:04 AM
glockedc's Avatar
is it normal for the car to bog down a little every now and then at a stop light when the A/C is on? I have an 09 with 71,000 miles. the dealership 3 month warranty is over in 500 miles. Needing to know in case I need to take it to them! thank you!!
Old May 10, 2016 | 03:37 PM
ThinBlue82's Avatar
Not sure what you mean? Do you mean the rpm's drop a bit while sitting at the stoplight? How often does this happen? Every time you stop? Could it be the ac compressor turning on?
Give us a bit more details and I am sure someone will be able to point you on the right direction. Personally, I'd say a little rpm drop when the compressor kicks on is normal but if you have a warranty which won't cost you anything I say take it to the dealership.
Old May 10, 2016 | 04:05 PM
glockedc's Avatar
It's only every once in a while at a stop light and drops from 700 rpm to about 550-600 and shakes the car for less than a second and then back to normal. It doesn't do it every time I stop. It probably is the compressor but doesn't seem like it should make the car shake for half a second. My old Corolla would do that but that's a huge difference in car.
Old May 11, 2016 | 06:58 AM
wildcat08's Avatar
It's from the compressor cycling on. Our Murano does it a little bit more than the Maxima. Kind of cheap feeling for sure. The 2.5L Altima I drove 83k miles never did it, though. I do wish they would idle a little higher, maybe around 800-850 rpm would smooth it out.
Old May 11, 2016 | 11:47 AM
Richard66's Avatar
Drive around for a couple of days without A/C on and see if the hesitation goes away. If it doesn't then the problem is elsewhere.
Old May 11, 2016 | 11:51 AM
glockedc's Avatar
It doesn't do anything weird or odd when the AC is off. so it is only when there is a load on it.
Old May 11, 2016 | 03:51 PM
ThinBlue82's Avatar
Then it's safe to say it's the ac compressor turning on.
JoshG
85
Jun 19, 2016 04:16 PM
Blue98444
Apr 11, 2016 04:31 PM
lowmaxx91
Apr 1, 2016 01:05 PM
BlackMaximus04
Mar 9, 2016 09:04 AM
slickblack94
Feb 29, 2016 10:33 AM
