L.E.D Reverse lights
It's not difficult. Just remove the black plastic clips inside of the trunk cargo area. Then pull back the covering to get access to the nuts which hold the lights in place. There may be a plastic clip attached to the end of the bolt. Just pull that off or use a screwdriver for leverage. Once you remove the nut from each of the bolts you're ready to remove the taillight. Use caution at this stage as the taillight housing is fragile towards the upper outer corner. While you gently pull the housing towards the rear of the car it helps to use a mallet or hammer covered by a cloth or tshirt to tap on the two mounting bolts inside the trunk. I believe ghozt did s write up on this years ago but I can't recall if it was posted here or another site.
Ahem guess I can finally say this to someone the answer to this question can be found using the searh function haha.
In all seriousness this should help by hamzer11 he also has a write up for the fronts and where to place load resistors to prevent hyper flash
https://maxima.org/forums/7th-genera...ulbs-leds.html
Zerodrag
May 26, 2016 06:16 PM
TBad2002
May 6, 2016 08:22 AM
