power outlet does not work
Old Jul 11, 2016 | 02:20 PM
Reza2016's Avatar
I have a Maxima 2013 and the power outlet located in front center console does not work. Any idea? If it is the fuse, which fuse should be replaced and how?
Old Jul 11, 2016 | 05:08 PM
Richard66's Avatar
Check fuse labeled "Fr power socket" inside fuse box. the fuse box should have a fuse puller stowed inside, if not a small needle nose pliers will work.
Old Jul 12, 2016 | 08:17 AM
Reza2016's Avatar
Could you tell me where is fuse box located? Under steering wheel?
Old Jul 12, 2016 | 04:22 PM
Richard66's Avatar
Fuse box is located just above the emergency brake.
Old Jul 13, 2016 | 09:24 PM
Another question that can be easily answered (fuse box location) by reading the owner's manual. Please read.
http://lmgtfy.com/?q=2009+nissan+max...ner%27s+manual
Old Jul 20, 2016 | 09:07 AM
ReneeNYC's Avatar
Crap, I have the same problem. I use the one in the center console as the middle front doesn't work. Opened the fuse box and I couldn't figure out which one it is. Still not working.
Old Jul 20, 2016 | 09:09 AM
ReneeNYC's Avatar
I'm going to revisit this issue. But if I remember correctly, the nissan book and my fuse box labels didn't match up. That's why I didn't change. I'm going to look again for the Fr power socket that Reza2016 suggested.
Old Jul 22, 2016 | 11:03 AM
Reza2016's Avatar
I changed the fuse and it worked to me. The fuse number was 20A.
Old Jul 22, 2016 | 11:54 AM
ReneeNYC's Avatar
Thank you. Pic was helpful also. Changing that right after work!
Old Dec 13, 2020 | 10:31 AM
Xavier Carr's Avatar
I replaced mine and still doesn't work one in the center console doesn't work either any other ideas
valerit1
May 19, 2016 04:13 PM
wingnut2000
Feb 24, 2016 06:53 AM
kest
Mar 2, 2006 08:26 AM
jurzyguy
Sep 12, 2000 09:11 PM
RussMaxManiac
Sep 6, 2000 06:13 AM
