P0826 code up/down shift switch circuit
Old Apr 17, 2017 | 10:23 AM
brian01983's Avatar
looking for some help. My Maxima is showing this code. The car runs and drives fine. Also shifts fine in both automatic and manual. I have seen fixes to this that include disconnecting the paddle shifters, but I don't have those.
any other suggestions?
thanks
Old May 16, 2017 | 08:33 PM
CALIHEAT's Avatar
Any luck? Just had the same code.My mechanic pointed it out during an oil change. I do not have a check engine light. I have a 2014 maxima.
Old May 17, 2017 | 02:47 PM
LtLeary's Avatar
If all the connections are good (and there are a few) the FSM calls for replacing the TCM. A bit draconian, but you should cause a Check Engine Light to come on. I am more a bit surprised that someone would connect a code scanner up during an oil change without any Check Engine Light on.
