Climate control issue 2010 Max...
Old Apr 30, 2017 | 08:13 PM
PJalst1's Avatar
I searched the forum, but couldn't find any posts with this issue.
Both my air conditioner and heat are blowing cabin temperature air. The blower is working fine, the air coming out is neither cold nor hot, whether I set it to A/C or heat.
Anyone else ever have this problem?
2010 Max with100K+ miles
Old May 7, 2017 | 07:32 PM
Maxgig's Avatar
It could be one of 3 things from what I've learned. #1, Possible but not likely could be out of date software, according to a Nissan tech I know. #2, It could be a bad climate control module, the good thing is that the part is relatively cheap and can be found on eBay and Amazon for less than $50 dollars.
And #3, if you had any dash related work done recently, if the wires were not pushed in completely you can lose certain functions. On the 2010, which is what I have as well, two of the plug connections are the same and are just long enough to reach either port.
I know this is a long shot but I hope it gets you in the right direction. Good luck.
Old May 8, 2017 | 11:54 AM
LtLeary's Avatar
Assuming you have plenty of refrigerant and the AC Compressor is working fine....
Try this link and go to the advanced menu. There is a page to reset the AC system from a diag perspective.
https://maxima.org/forums/7th-genera...vice-menu.html
Old May 8, 2017 | 02:15 PM
PJalst1's Avatar
I bought the car used 2 years ago and I havent had any dash work done. I'll try that Diag first, refrig and Control module(in that order). I'll let you know how it turns out.
Thanks for the tips guys.
