5 chirping beeps from driver side
Old May 8, 2017 | 05:01 AM
jose978's Avatar
i just recently purchased a 2011 sv and had no problems until a couple of days ago. when i start up the engine i can hear 5 loud chirping beeps coming from the left driver side dashboard. it only happens when the engine is cold. if i turn the car off and then turn it on again before the engine gets cold it doesn't do it anymore. i looked in the manual but i cant find anything on this. does anyone know what it could be.
Old May 8, 2017 | 07:20 AM
glockedc's Avatar
Someone may be able to confirm this as well but mine beeps a few times as well and I believe it like an initial diagnostics check.
Old May 8, 2017 | 11:16 AM
LtLeary's Avatar
Sounds a bit like seat belt alert. Is the seat belt light on at the same time? The driver's side will only chirp for 6 seconds so this "may" be your issue...especially if you are a light person or the sensor is defective.
Old May 8, 2017 | 01:14 PM
jose978's Avatar
I dont think its the seatbelt the first time i noticed it it only chirped 3 times now its doing it 5 times and i just turned it on and it did it 7 times. its not a beep like a seat belt its a louder chirping sound like a high pitched bird almost. it sounds almost like an alarm.
Old May 8, 2017 | 02:12 PM
Richard66's Avatar
Serpintine belt or the tentioner bearing??
Old May 8, 2017 | 02:24 PM
jose978's Avatar
Thanks ill check i out but just to be clear the sound is not coming from the engine it sounds like its coming from a speaker in the car like a warning system.
Old May 8, 2017 | 02:29 PM
Richard66's Avatar
With the doors closed turn the ignition to the acc or on position without starting the car does it beep?
Old May 8, 2017 | 02:44 PM
Richard66's Avatar
Another thin to try is get in car, shut door, buckle up the seat belt then start the car. Beep still there??
Old May 8, 2017 | 07:01 PM
jose978's Avatar
The beep only sounds when I start up the car. I tried locking the doors and putting the seatbelt on and I still heard it. This time it was 8 beeps and the time before it was 7 so I think everyone I start the car it adds an extra one.a
Old May 8, 2017 | 10:25 PM
Richard66's Avatar
Any chance you can post a video sound clip of this??
Old May 8, 2017 | 11:09 PM
jose978's Avatar
I'll post one after i get out of work.
Old May 9, 2017 | 10:06 PM
jose978's Avatar
I don't know what it was but it isn't doing it anymore. I got out of work turned it on and it didn't beep. I've turned it on 3 times since and it hasn't done it on any of them.
Old May 10, 2017 | 07:07 AM
Les7311's Avatar
Can you do a video or sound clip then post it?
