Fog lights not working
Old Jun 1, 2017 | 02:43 AM
tviper1's Avatar
Hello Friends,
I tried to upgrade my 2014 maxima's fog lights to LED, and they worked very briefly and then stopped working. In fact, now the fog lights won't come on at all. The fuse is working, but there isn't power coming through the fog lamp harnesses. I suspect the only thing left would be the relay. Has anyone encountered this issue? And if so could you share how you were able to fix it?
Thank you in advance.
Ty
Old Jun 1, 2017 | 04:30 AM
MadMax07SL's Avatar
First off, did you try the working incandescing bulbs again, and do they work, or not?
Old Jun 1, 2017 | 08:33 PM
tviper1's Avatar
Hello Madmax, no they do not work.
Old Jun 18, 2017 | 06:33 PM
tviper1's Avatar
Has anyone encountered this problem with their 7th gen. Maxima? If so please share your thoughts.
Old Jul 1, 2017 | 07:23 PM
jbratsSV's Avatar
Yes and it as my fuse dealer changed at no charge it may be your fuse... I made sure that when I reconnected them that I greased the terminals... and now there working no problem hope that helps and I did not use led lights with ballast it's going right into socket.. full power and very bright.
