Remote Power Wire
Remote Power Wire
I'm sure this has been asked already but I can't find it. I am running an amp to the factory system in my 13 Maxima. Which fuse in the fuse box can I tap into that is 12v? Thank you.
there are whole bunch in the fuse box that are accessory power that are open you can use an add a fuse..if you have BOSE i think there is a powerlead you can tap from the trunk...i will see if i can get a shot of the wiring diagram
In case anyone else searches this, I spliced into the same wire that turns on the Bose amp instead of running another wire alway to the back. I can't remember which wire it is, but there is a write-up on the Infiniti forum (check M35 forum year 2006). The only wire I ran from the front was the power wire from the battery.
