CVT issue, please help
Old Feb 7, 2019 | 03:43 PM
insiteful01's Avatar
Today 8 changed my CVT filter and fluid. The car will not go into any gear now. I have double checked all fluid levels and it appears to be where it was prior to draining. I was experiencing intermittent "limp mode" prior to attempting the fluid change.
could this be due to an incorrect amount of fluid in the tranny?
thanks in advance for any help!
Old Feb 7, 2019 | 05:19 PM
mahanddeem's Avatar
What fluid was it before? What fluid did you use?
Old Feb 7, 2019 | 08:06 PM
Richard66's Avatar
Well you are 4 years and 70,000 miles past due on your cvt oil change. No wonder you are experiencing limp mode.
What oil did you use for the change, and does the dip stick read full?
Old Feb 8, 2019 | 03:38 AM
NS2, replaced with NS2.
Old Feb 8, 2019 | 03:40 AM
I used Nissan brand Ns2 fluid. Dipstick reads full.
Old Feb 8, 2019 | 04:49 AM
MadMax07SL's Avatar
The infamous fluid swap tranny don't work no more syndrome. Yeah, if this was the first swap, you waited to long most likely. switching out the fluid didn't break the CVT, but it did expose the problem right quick. It's likely time to get it towed to a shop and probably replace it, as I don't think anyone is rebuilding these in the shop...just replacing them.
Old Feb 8, 2019 | 07:37 AM
tbm5690's Avatar
Try pulling the battery cable to reset the PCM...sounds like it likely won't help but doesn't hurt to give it a shot.
Old Feb 8, 2019 | 08:58 AM
mahanddeem's Avatar
Are you sure you did not disconnect any wiring? in and out hoses for the filter correct position, any leaks, any CEL?
Old Feb 8, 2019 | 10:40 AM
mahanddeem's Avatar
Hopefully the valve body is not toast!
Old Feb 9, 2019 | 02:56 PM
LtLeary's Avatar
Well, you did mention you changed the filter too. When I did a "flush" I too couldn't get any gear. It was actually low on fluid. Try 1 more quart and see if that "fills the bubble" Not much to lose at this point
bbsitum
Aug 16, 2014 11:38 PM
mikeo6000
Fluids and Lubricants
Jul 25, 2014 09:52 PM
3rdcharm
Oct 23, 2008 05:33 AM
2002 Maxima SE
Jan 19, 2004 04:45 PM
OnTheRoad
Dec 1, 2000 03:26 PM
