Low rough idle
Old Apr 9, 2019 | 09:12 PM
JoeyJoseph's Avatar
Low rough idle
My 2012 Max has had a fluctuating idle from about 650rpms to as low as 550rpms at stop in gear and in park. The engine compartment has noticeably become more unsteady with a slight vibration with the low rpms. The weird thing is sometimes i experience a bit of a bogginess upon acceleration but sometimes performs as if it were new again when accelerating. It is a random problem that seems to be getting worse. The car performs great at highway speeds. Can the CVT cause a low rough idle? Another clue is the engine really bogs down at a stop when a load is applied like using the power windows or using the AC. Anybody out there cure these symptoms? Ive cleaned the throttle body, changed the sparkplugs, checked for vacuum leaks (seems to be none with soapy water and spraying sensor cleaner), changed out the intake idle air control valve, changed air filter, changed MAF sensor, and used Gumout fuel system cleaner with PEA a couple times. Any input would be greatly appreciated.
Old Apr 10, 2019 | 02:22 AM
User1's Avatar
How do you check for a vacuum leak using soapy water? I was not aware that gen7's had an IACV? How many miles are on your car? Have you tested your battery and charging system? Have you scanned for codes?
Old Apr 10, 2019 | 06:41 AM
mahanddeem's Avatar
Seems like a fuel/air ratio issue, vacuum leaks, air filter, MAF, dirty throttle body, cracked air intake, fouled spark plugs, worn ignition coils, worn oxygen sensors, etc.
Though you seem to have tackled most of these! Have you ever performed idle air relearn and/or throttle position relearn? it is a CONSULT procedure, paddle dance or CVTz50 can do the idle relearn, do some research on that.
Mileage? as User1 said, get a code scanner and see if you have a hidden DTC. I doubt a CVT can cause idle issues
Old Apr 10, 2019 | 07:00 AM
JoeyJoseph's Avatar
The soapy water method is like checking for a leak on a tire. The IACV is known as a Intake Manifold Idle Control Valve. I have 204K kms (not miles) on the car and the battery and alternator seem to check out with the correct voltages. There is no check engine light and no codes pop up with the scanner.
Old Apr 10, 2019 | 07:03 AM
JoeyJoseph's Avatar
Thanks for the response. I will try the relearn idle process today! Will keep you updated on the results. Car has 204K kms and there are no hidden codes popping up when using a scanner.
Old Apr 10, 2019 | 09:23 AM
Richard66's Avatar
You didn't load test the alternator or the battery? It needs to be done.
How old is your battery?
Reading voltages does not give you the health of the electrical system.
These cars can develop all kinds of problems when the electrical system is not up to par.
Old Apr 10, 2019 | 07:30 PM
User1's Avatar
Leaky tires are under positive pressure. Vacuum lines run negative pressure. Ponder that... These cars are fly by wire, no IACV. Like the previous poster mentioned, power and charging system first. Everything about everything on modern cars is computer controlled and needs clean power. You a Canuck too, eh?.
Old Apr 10, 2019 | 07:53 PM
JoeyJoseph's Avatar
Will give the load test a try. The battery is about a year old. And voltage checks out normal.
Old Apr 10, 2019 | 07:54 PM
JoeyJoseph's Avatar
Thanks for the helpful comments.
Old Apr 10, 2019 | 07:55 PM
User1's Avatar
Good luck.
Old Apr 18, 2019 | 05:56 PM
Nmax5150's Avatar
Try the simple thing first.. Clean that Throttle body .. if it is dirty.. it will cause a low or rough idle... Do not use brake clean.. only use throttle body cleaner .. just use a rag or micro fiber towel.. a tooth brush works great ..
Old May 5, 2019 | 06:09 AM
Bluedawn0001's Avatar
Loosing my mind trying to find the intake air control valve
ive spent 2 hours on the car and online trying to find this dang part! I have idle issues when cranking as well as a code that says the idle air control is bad. I guess the 2012 is intake air control? But where is it? Driving me mad. Nothing online at all. It’s all gen 6,5 etc nothing gen 7
Old May 5, 2019 | 08:20 AM
Richard66's Avatar
Did you clean the MAF sensor and/or check for vacuum leaks. Both of those will mimic a bad idle air control valve, and will cause a rough idle
BTW what was the specific code you get?
Old May 5, 2019 | 09:39 AM
mahanddeem's Avatar
Where did you search?
Old May 5, 2019 | 02:49 PM
User1's Avatar
ive spent 2 hours on the car and online trying to find this dang part!7
What part?
Old May 5, 2019 | 03:29 PM
sesrched all around that area. Nothing there. Took off the throttle body, nothing attached to it.
Old May 5, 2019 | 03:36 PM
i just started at the error first before looking for anything else. I’ll have to find the error but I remember it saying specifically the idle control valve was bad and the system was running rich. A few weeks prior to this one day got in it cranked it up and it stalled a few times. Took 10 min to get it running then it ran fine. No check engine light but put it on a computer anyways and it came back with a misfire code. So went online and see tons of post about the exact same issue with this car just like the one here (sorry for hijacking ur post figured same issue maybe get somewhere). It also hesitated at idle within idling in low gear and you hit the gas it will almost sputter. Also the lights seem to flicker a little (praying not a coil pack).
So bought some seafoam but then a other place said nah use good carb cleaner take apart throttle body clean it out, pull out iacv clean it etc etc. so can’t find it to clean it. And the throttle body wasn’t that bad $120k miles.
I did just have to replace bad radiator radiator fan and found a small radiator leak (will fix later). So not sure if motor overheating a few times could have caused any issues. But just seems a common issue so went to ground zero first.
Old May 5, 2019 | 03:40 PM
User1's Avatar
There is no IACV. You're looking for something that doesn't exist.
Old May 5, 2019 | 04:18 PM
User1's Avatar
Talking
Are you praying hard enough?
Old May 7, 2019 | 01:03 PM
P0507 - idle air control system RPM higher than expected. - idle air failure - idle air system has higher voltage than expected.
Reason for failure - high mileage and age
recommendation- check throttle body for damage before rebuilding.
Thats the code and info I got. Some people say it doesn’t have one but parts stores do sure sell one. It’s separate and seems to attach somewhere else.
Old May 7, 2019 | 01:42 PM
Autozone does not think outside of Ford or GM, (maybe Chrysler if you encounter a talented autozone personal)
The only part controlling air intake is the throttle body. Your looking at $290 reman part from Nissan.
I trust oem parts never had an issue with them. With that being said I called a mechanic at the dealer so I can try and get this done. He went along with what was said above (already had it on my list to do) which was check for vac leak. Just for anyone else comes looking with same issue, he said this car and engine has issues on the left side with vac leaks. So adding that to the list.
Check and clean map
clean throttle body
replace throttle gasket
check for vac leaks
Old May 7, 2019 | 02:27 PM
LtLeary's Avatar
I am trying to remember all the vacuum line sizes and am coming up blank (I slept a few times since I did it) but it will save you a lot of time if you just start pulling them off and replacing them one at a time. With all the heat cycles, they do get fragile and crack. I think it only took a few hours max to replace them all and if you buy them in a retail shop they come in 6 or 10 ft lengths. I don't believe I used more than 1 pack of any given size.
Old May 7, 2019 | 07:10 PM
User1's Avatar
Granted I am using a '14 motor in a 5th gen body, but my vacuum connections were quite simple and I didn't have to plug anything that wasn't required for the swap. They are:
1) Bank 1 Brake booster
2) Bank 1 PCV
3) Bank 2 breather to airbox
Not much to it for vacuum lines. Bank one lines are pretty short, not more than 6" or so.
Should you opt for a TB replacement, here is a good deal OEM Hitachi unit:
https://www.ebay.com/itm/Fuel-Inject...6/323775766969
Old May 8, 2019 | 12:05 PM
LWilspeed's Avatar
TO OP: JoeyJoseph. Do your lights flicker? Like interior lights, or even headlights? And/or do you head a slight popping noise through your sounds system when activating electric loads (turn on headlights, etc)? If you notice either of these, I agree with the earlier advice to check charging system. I've seen this on 7th gens, including my own. Ended up being a corroded connection where the negative battery cable bolts to the top of the transmission. Takes some work to get to it because you have to pull the battery tray out. This is a long shot but I thought it might help. If you have the other symptoms just cleaning the cable end and the transmission boss it bolts too will do wonders for your car.
Old May 8, 2019 | 07:14 PM
User1's Avatar
OP is gone. Account creator passing through looking for a quick answer and maybe save a buck so they can get to work the next morning. There's gotta be a name for that type, no?
Old May 9, 2019 | 03:11 AM
LWilspeed's Avatar
Sorry, I just got excited about the first question.
Old May 31, 2019 | 08:23 PM
VeeQue35DE's Avatar
The IAC on your car is the electronic throttle body. On older cars, usually drive by cable, the IAC is separate and can be changed out. So new or old, it's there, but when it's electronic controlled and non-replaceable then it's not mentioned. You should go through the Idle Air Volume Learning procedure before you continue with a new throttle body purchase. It's free anyways and you'll have to redo the procedure if you buy a new one (so count this as practice). You may want to have a timer ready on your phone.
Start engine and warm it up to normal operating temperature. (Temp needle in the middle)
Turn ignition switch OFF and wait at least 10 seconds.
Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds. (K.O.E.O. - Key On Engine Off)
Repeat the following procedure quickly five times within 5 seconds. - Fully depress the accelerator pedal. - Fully release the accelerator pedal.
Wait 7 seconds, fully depress the accelerator pedal for approx. 20 seconds until the M.I.L. (Malfunction Indicator Light / Check Engine Light) stops blinking and turns ON.
Fully release the accelerator pedal within 3 seconds after the MIL turns ON.
Start engine and let it idle.
Wait 20 seconds then W.O.T. (Wide Open Throttle / Snap Throttle) two to three times.
Wait for the RPM gauge to settle back down and it should over between 600 to 750 RPM's nominal value.
Old Jan 19, 2021 | 04:14 AM
Sal.1027's Avatar
Has your issue been solved yet?
ryant35
35
Jun 30, 2008 09:35 AM
Fork
Sep 3, 2006 07:58 PM
davids
Oct 18, 2004 11:54 AM
99maxk2
Sep 25, 2004 09:11 PM
