Key not recognized in key port
Old Oct 30, 2019 | 03:53 PM
harvey02's Avatar
I am installing a remote starter in my car, and and in order to program it I need to put the key into the keyport so the module can copy the info off the key. The problem is that the key is not being read properly. I tried taking out the battery from the key and putting it into the keyboard and the car will not start, even though it really should since if you have a dead battery and you put it into the keyport the car will start. The screen just says insert key. Anyone have any idea why this would happen? Thanks!
Old Oct 30, 2019 | 04:41 PM
Richard66's Avatar
Did you try your second remote?
Old Oct 30, 2019 | 04:53 PM
harvey02's Avatar
Just when I need it, I can't find it
Old Oct 31, 2019 | 08:17 AM
Richard66's Avatar
Can you put your car back to stock then try the remote. If it works then there is something wrong with the remote start install.
Old Oct 31, 2019 | 10:10 AM
harvey02's Avatar
Thanks! I tried that but have the same issue.
Old Oct 31, 2019 | 01:28 PM
VeeQue35DE's Avatar
If you reverted back to stock and it works but doesn't after the remote start system installation then it sounds like a problem with copying the transmitter code algorithm or the module itself. Try contacting the manufacturer of the remote start system to troubleshoot it or have an authorized security specialist install the system. If you're working with Clifford/Viper then have an authorized dealer install it. I have seen problems with trying to pair a replacement key / additional keywhen those systems are installed. It prevents adding on additional keys to the vehicle key registry and would have to be removed in order to add a key. Contact the manufacturer.
Old Oct 31, 2019 | 01:33 PM
harvey02's Avatar
Hi, sorry if I wasn't clear but even after I reverted back I still have the same issue. The key port does not recognize the key.
And, the remote start I am installing is the Fortin Nist1 with the T harness.
Old Oct 31, 2019 | 07:33 PM
VeeQue35DE's Avatar
You connected all the harnesses correctly after removing the T harness? Was the NIST1 module on the latest firmware? Double check your work and also check the fuse box if any fuses are blown. Did you install the hood pin? On my older Viper 2-way remote start alarm system, the hood pin had to be depressed to use remote start.
Like I said, contact the manufacturer for troubleshooting or confirmation.
Jim Vollmer
May 14, 2019 07:07 AM
michaelm815
Jan 18, 2011 04:09 PM
gold4dsc
Feb 16, 2009 07:41 PM
MAXTIZZLE
Nov 26, 2005 08:03 PM
MaxTooNice
Mar 11, 2005 06:24 AM
