avital 4400 remote start
Old Feb 14, 2009 | 07:56 PM
gold4dsc's Avatar
ok so trying to put my remote start in the 00. heard about and dapter in the car for the key. can some one explain to me what they are talking about??
Old Feb 14, 2009 | 08:09 PM
MysticCBR's Avatar
bascially inside the key there is a little "chip" without the car seeing that cose car wont start ....its so people cant steal the car without the chipped key ...im a MECP installer if you need more help or the bypass shot me a PM ...
Old Feb 15, 2009 | 07:57 AM
nsnrider's Avatar
You have to bypass the transponder key in order to have the remote starter to function properly. Otherwise, the security software would assume the car is being stolen, will cut off the fuel and after a few attempts, lock up the system so you won't be able to start the car even with the original key. You'll have to unlock it.
IIRC, there are two different module, the one that you leave an original key copy in the box under dash at all times or the one than you program to mimic a transponder chip. I would advice the second one since its a bit safer since there is no key in the car for someone to break into it and drive off with your car, which is possible with the first option.
Are you planning on doing this yourself? Unless you know exactly what you're doing, I would recommend to have this professionally installed.
Good luck.
Old Feb 15, 2009 | 04:20 PM
gold4dsc's Avatar
i have installed this alarm b4 on my 98 so i just need to know how to bypass with the key i went to my local install shop and they trying to charge me 200 to put it back in and the only thing i dont know how to do is the by pass
Old Feb 16, 2009 | 05:49 AM
djfrestyl's Avatar
Suspension Yoda
The module that holds a spare key locked in a box is the 556U.
The one that requires programming is Xpresskit.
http://www.sjgreatdeals.com/deixk02.html
The 556U is cheaper, and probably doesn't require you deal with software on your PC.
edit: also, this should be in the audio/electronics section, you would have gotten a much faster and knowledgeable response.
Old Feb 16, 2009 | 07:41 PM
MysticCBR's Avatar
look into a idatalink pieace ...i just installed one last week and used this module very easy ...like i said if you need help or need the module PM me ill help ya out
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
