Driver side CV Axle
Old Feb 28, 2020 | 11:35 AM
Nestorsh's Avatar
Driver side CV Axle
Anyone had replaced the Driver side CV Axle?
I need to replace mine, but I'm not sure if the CVT Fluid will come out, if so would be a lot of it?
Old Feb 28, 2020 | 12:31 PM
20_Maxima_10's Avatar
Some will come out. but not very much. you'll be fine
Old Feb 28, 2020 | 12:42 PM
mahanddeem's Avatar
I think it's a perfect chance to drain and refill and check level afterwards.
Old Feb 28, 2020 | 04:57 PM
LtLeary's Avatar
None came out .when I did mine, but then again, i had my drivers side on jackstands so all the fluid goes to the other side. Just know that the clip in the end of the axle is such a joy to get seated.
Old Feb 29, 2020 | 06:13 AM
Nestorsh's Avatar
min working on this right now, I was about to ask about that, I can put my finger nail between the axle and the tranny, if I pull a little the gap gets bigger, can get it tight, about the tranny fluid got almost 2qt out. FML
EDIT: I tried to take it out completely again and re try but it’s locked already, so I guess the ring clip is on?! But I still feel a gap with my finger nail between the tranny and the washer on the axle
Old Feb 29, 2020 | 08:36 AM
LtLeary's Avatar
Sounds like the seal is defective. You will most likely need to replace that. Re getting the axle out, place trans in neutral (after securing the car with chocks) and rotate a bit at a time. Push/pull straight in and out, if at an angle it will never come out.
Old Feb 29, 2020 | 09:02 PM
User1's Avatar
Get a long *** flathead screwdriver or prybar between them and pop that sucker out. There's nothin to it. Do a quick switch with the new one and minimize fluid loss. Run that fluid through a coffee filter as you're pouring it back into the tranny. Good to go.
Old Mar 2, 2020 | 06:02 AM
MaximusN8's Avatar
How did you make out with this? Just a heads up your lower control arm needs to be replaced the bushing looks very dry and cracked.
Old Mar 2, 2020 | 07:54 AM
Nestorsh's Avatar
I got the axle, and yes, thats right, I'm in a point where i have to fix some stuff on this car, Ill change struts and later control arms
Old Mar 2, 2020 | 09:17 AM
MaximusN8's Avatar
I'm in the same boat, My left lower control arm is bad and needs to be replaced. I also need front brakes and my right CV axle is leaking grease from the clamp on the inner boot, and then I got some rust/paint bubbling on my right rear door so I too have some things I need to repair on my 2010. What brand CV axle did you go with are you noticing any difference while driving such as vibration etc pertaining to the CV axle? I've heard mixed reactions that replacement aftermarket CV axles are giving vibrations at certain speeds.
Old Mar 2, 2020 | 09:26 AM
Nestorsh's Avatar
I did carquest, from AAP, I also did the passenger side about a year ago, everything good, no problems, I has some vibrations, but I checked my caliper guide pins, grease was dry but i just cleaned them i put some new grease and problem solved.
Old Mar 2, 2020 | 09:30 AM
MaximusN8's Avatar
Nice, how did you make out with the Axle seal did you have to replace them on either side when you changed the axles?
Old Mar 2, 2020 | 09:35 AM
Nestorsh's Avatar
I did replace them. they are cheap so i just went and change them.
Old Mar 2, 2020 | 09:54 AM
MaximusN8's Avatar
Were those easy to put in did you need any special tool for them?
Old Mar 2, 2020 | 07:45 PM
Nestorsh's Avatar
driver side I just did it by hand and I think I did the same with passenger side, isn’t that hard to do it, I was little scared but now that I did it, is not that hard
Old Mar 3, 2020 | 04:35 AM
MaximusN8's Avatar
Something I'm going to be tackling on the passenger side, not looking forward to it..lol I'm going to try the best I could to remove the axle with out damaging the seal and hopefully prevent trying to replace it, I live in Massachusetts so I'm sure I'll be dealing with some rust.
Old Mar 3, 2020 | 05:09 AM
Nestorsh's Avatar
I dont think is easy to damage the seal, but dont take the chance, if you replace your axle and then you have a leak you will have to re do it, its a quick job but still. when I did the passenger side I didn't have any fluid coming out.
Old Mar 3, 2020 | 05:13 AM
MaximusN8's Avatar
Thanks for the info, Yes I heard the drivers side loses more fluid than the passenger.
ukraini9mofo
May 1, 2006 08:17 PM
Batxel
Sep 1, 2005 10:32 AM
FasMaxVE
Feb 4, 2005 06:14 AM
