P0725
Old Aug 26, 2020 | 06:10 PM
2010maxedout's Avatar
P0725
How do i change crankshaft sensor. 2010 maxima. I am getring code p0725
Old Aug 27, 2020 | 03:14 PM
Costee's Avatar
I can't see how the crankshaft sensor relates to this code, which refers to a break in engine speed signal between the ECM and the TCM. The worst case scenario is to change the TCM.
Old Aug 27, 2020 | 06:23 PM
User1's Avatar
CKP is a perfectly reasonable cause, and in my opinion, probable.
https://www.engine-codes.com/p0725_nissan.html
P0335 in the engine control section of my 2014 FSM correlates to your P0725, despite not being directly listed in my FSM. There is another list of relative, yet less common fault codes that DennisMik, or some other member posted a while ago but I couldn't find the file to reference. P0335 will have your CKP work flow. Or you could just skip the hard stuff, replace the CKP and clear the code. It's on the front of the engine, near the bottom, where the tranny mates to the block. Jack the car up, remove the splash guards and swap it out.
Old Aug 28, 2020 | 12:19 AM
Costee's Avatar
Yes, I think you're right having gone through the TSB mentioned in the link.
Old Aug 29, 2020 | 08:33 PM
The code has disappeared for now but I will still try to change it. I did see that website so that is why i wanted to Change the crankshaft sensor. Thanks
adi1991
May 28, 2020 06:32 AM
MAAA
Jul 25, 2017 08:54 AM
enik23
Jul 18, 2008 12:44 PM
colonjdb
Feb 27, 2005 07:29 AM
