cel p0507?
https://www.my4dsc.com/nissan-info/f...ervice-manual/
Captive8 is correct but lets get you a little closer. You are looking at a bad pcv valve/hose or air leak most likely
Here is the test procedure for the P0507Diagnosis Procedure
1. CHECK PCV HOSE CONNECTION Confirm that PCV hose is connected correctly.
Is the inspection result normal?
YES - GO TO 2.
NO - Repair or replace malfunctioning part.
2. CHECK INTAKE AIR LEAKAGE
NO - GO TO 3.
3. REPLACE ECM
YES - GO TO 2.
- Start engine and let it idle.
- Listen for an intake air leakage after the mass air flow sensor. Is intake air leakage detected?
NO - GO TO 3.
3. REPLACE ECM
- Stop engine.
- Replace ECM.
scottcarlsonMAX
Dec 25, 2003 10:19 PM
JR_Anders
Aug 10, 2002 11:27 AM
