ECU reprogram is a "MUST" after OEM MAF replacement?
Old Apr 5, 2021 | 11:15 AM
mahanddeem's Avatar
I have an intermittent CEL with P0101 (MAF code) in my 2011 100k miles. Car drives beautiful with no problems at all. But I decided to go ahead and get a new OEM MAF from Courtesy Nissan. I cleaned the MAF a year ago but still, code pops up these days. Should it need dealer reprogram? A new MAF only or both? That's what I hear but never replaced MAF on this car before. I'm asking if it is necessary. Thanks.
I'd put the sensor in as soon as I get. I heard conflicting stories of some people just replaced the sensor and some needed a reprogram.
Old Apr 5, 2021 | 11:49 AM
Richard66's Avatar
https://autovfix.com/mass-airflow-se...0reprogrammed.
According to this article it depends on the model of the car and should indicate in the instructions if the reprogramming is needed.
Let us know how it turns out.
Old Apr 5, 2021 | 02:43 PM
Get the answer straight from the horse's mouth. Download the FSM in signature and follow the guidelines for troubleshooting the MAF code P0101. I'm sure the FSM will identify whether reprogramming is necessary. If not in that section, then check other sections of the FSM.
Old Apr 6, 2021 | 07:28 AM
BlackCrimsonChin's Avatar
There's a bulletin out for P0101, basically says you need to get the reprogram done to get rid of the code. I had the same issue, but a week or 2 after I changed the sensor the code went away. This was after having the code for about 4 months. It's been 2 months now so here's hoping it's for good.
Old Apr 6, 2021 | 08:52 AM
Link to said bulletin?
Old Apr 6, 2021 | 08:55 AM
https://static.nhtsa.gov/odi/tsbs/20...19172-9999.pdf
Old Apr 7, 2021 | 03:15 PM
Maxboost23's Avatar
where would the MAF Sensor be under on the FSM?
Old Apr 7, 2021 | 04:25 PM
User1's Avatar
Just replace it and go. You don't have to do anything else.
Old Apr 7, 2021 | 09:16 PM
Maxboost23's Avatar
I did replaced it and its still throwing the P0101 code.
Old Apr 7, 2021 | 09:24 PM
User1's Avatar
Clear it.
Jereme329
Mar 29, 2010 02:32 AM
Epacy
Jul 26, 2005 08:52 PM
koostermax
Jul 19, 2005 09:21 AM
merovi
Mar 25, 2005 08:34 PM
tkarrh
Jun 25, 2003 05:47 AM
