what is MAF code
Old Mar 15, 2005 | 06:43 AM
merovi's Avatar
what is MAF code
I'm going to get the codes pulled today and i'm 99% sure its the MAf. What is the code that says it is a MAF problem.
Old Mar 15, 2005 | 07:03 AM
Puppetmaster's Avatar
See here:
http://forums.maxima.org/showpost.ph...&postcount=100
Old Mar 15, 2005 | 07:05 AM
Progress's Avatar
It's business time.
I'm not sure if it will throw a code, I remember when I got my MAF replaced under warranty at the dealer they recorded it as the MAF making an O2 sensor read wrong making the fuel mix lean. I know that there was no SES or CEL when mine blew.
GL
Old Mar 15, 2005 | 07:08 AM
merovi's Avatar
thats what i'm worried about. I have every problem of the MAF.
strong hesitation at 3400 RPMS
stalling in the cold.
rough start on cold mornings
but the rents want me to pull a code before i fix anyhting
Old Mar 15, 2005 | 07:12 AM
Progress's Avatar
It's business time.
If you have an Autozone nearby, then it definitely won't hurt. If you let the dealer repair it, they're gonna charge you an hour's labor for the diag. fee. I'd get the code pulled, regardless if there is one or not, get a new MAF and install it yourself. If you have a warranty just take it to the dealer.
GL
Old Mar 15, 2005 | 08:14 AM
rule da road's Avatar
i had code p0133, heated sensor and my car ran with terrible with MAF-lke problems. Swapped my own MAF, car pulls strong thruout band and my SES hasnt come back on.
Old Mar 15, 2005 | 10:30 AM
geenowalker's Avatar
you may also get the P017? codes for lean bank or rich bank. I got those, replaced the MAF and max was back.
Old Mar 15, 2005 | 11:47 AM
merovi's Avatar
i got codes
P0325
P1320
i know one of these is for the knock sensor but i have absolutley NO knocking at all.
and the other is for ignition signal but ALL ignition coils have been replaced whithin the last year or so.
any ideas? i still believe its the MAF but i want some input
Old Mar 18, 2005 | 07:44 PM
Out-of-Focus's Avatar
The P0325 knock sensor code does not cause a SES light, and the code is not due to knocking but due to improper voltage signal being sent to the ECM.
Old Mar 18, 2005 | 08:15 PM
Bensmax00's Avatar
i got codes
P0325
P1320
I have yet to see a maf set a 1320 code--mafs usually set a p0100(maf sensor) or the system lean code I for got the # for it--most bad mafs dont even set codes unless it really is a problem my maf never set a code--my car just ran ruff--then i put my maf in another max and that car ran ruff so that how i knew it was the maf---but 1320 is the coils--if u got them replaced clear the code and if it comes back then u need to find out which coil or coils is bad
Old Mar 21, 2005 | 06:09 PM
grange's Avatar
Does anyone know what the screen on the end of the maf tube is for?
Old Mar 21, 2005 | 06:37 PM
Progress's Avatar
It's business time.
Some say it is to prevent turbulence right before the sensor and I think it may act as a last defense for the engine and sensor to make sure nothing gets in there. If you are wondering if you should take it off or not, I think the rule is to keep it on as it won't effect performance for the better if removed.
GL
Old Mar 25, 2005 | 08:34 PM
illmattic979's Avatar
I also have hesitation and rough idle. changed coils and plugs nothing changed. SES light on codes p0171, p0174 (lean banks) plus codes p0464 and p0500. I wonder if the MAF could be my problem too.
TallTom
57
Oct 14, 2025 05:16 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
