Trac cont. Lights coming on.
Old Jun 29, 2021 | 09:43 PM
Vinar's Avatar
Question Trac cont. Lights coming on.
Heya Max Fam! I just installed the Stillen rear sway bar on my 2010 SV along with some Michelin Primacy 4x4. I noticed the trac. control light and swerving symbol lights up after driving for like 30 mins. I am getting alignment on the 1st do you think that is the problem? Also does the Stillen rear sway bar use different bushings? The instructions just said use stock hardware I put some new brackets and bushings on the bar.
Old Jun 30, 2021 | 02:58 AM
LtLeary's Avatar
I really dont know about your stillen but make sure your brake fluid is topped off. Low fluid level is perhaps the top reason by far for the traction control/abs lights.
Old Jun 30, 2021 | 02:20 PM
Captive8's Avatar
Originally Posted by Vinar
..... Also does the Stillen rear sway bar use different bushings?.....
No, the Stillen rear bar is the same OD as the factory bar, so using your original hardware is fine.....it's a thicker wall tubing.
Old Jul 14, 2021 | 10:51 PM
Vinar's Avatar
Red face
Thanks! After I got the alignment the light stopped coming on so I guess it knew it was out of spec.
AboveDaCloudz
Apr 14, 2016 05:46 AM
dannyhightower
Oct 25, 2010 09:45 AM
petenycmax
Oct 26, 2000 04:50 PM
