Lights fluttering after Alternator
Old Jan 30, 2022 | 10:45 AM
MaximaMan24's Avatar
Can you guys help me figure out my problem! The lights on my 2011 have been fluttering since I replaced the alternator. It’s does it randomly at idle and can feel it with the engine running and I’ve replaced 3 alternators plus battery hoping it would solve the issue but no luck. The voltage go up and down when checking with multimeter and stabilize when it stops. It has to be something else I can look at any help would be appreciated
Old Jan 30, 2022 | 12:05 PM
Bificus99's Avatar
Where are you getting the alternators from? Did you test the original before replacing it. I just got thru that mess. Assumed it was my alternator on my Z and got a bad one and then it was the regulator the whole time.
Old Jan 30, 2022 | 12:23 PM
I got the first one from advance auto parts and that’s when the problem started, then went orielly and that one was bad because it stopped charging and I currently have a Bosch alternator and it’s still fluttering. The original one went bad because of the aftermarket sound system I had in it
Old Jan 30, 2022 | 04:17 PM
TDGrant's Avatar
Did you disconnect the sound system to see if the fluttering went away?
Old Jan 30, 2022 | 04:28 PM
Yes I removed it completely and no change
Old Jan 30, 2022 | 04:29 PM
TDGrant's Avatar
Dang!
Old Jan 31, 2022 | 04:31 PM
Well, it's either the alternator or the wiring associated with and connected to the alternator. Start by checking all alternator related connections, then test the alternator using a multimeter. Plenty of videos on Youtube explaining the process.
Old Feb 2, 2022 | 05:45 PM
User1's Avatar
Even the Z is internally regulated, same motors. OP mentioned aftermarket stereo, so who knows what monkeying around has gone on with that car. Tough to troubleshoot a mess of hacked wires over the internet.
paulpearl
Aug 3, 2014 11:57 AM
HarrisH
Jan 26, 2005 06:18 AM
takkar
Nov 19, 2004 12:14 PM
Ivan Yulaev
Aug 19, 2004 11:19 PM
HarrisH
Oct 16, 2003 10:27 AM
