Stall at red lights or traffic
Old Dec 16, 2023 | 08:06 PM
DEXT3R's Avatar
Angry Stall at red lights or traffic
Recently my car is stalling usually at red lights or stop and go traffic.
I get TRACTION & ABS lights on the dash.
Turn the car off and on and everything is back to normal !
but the stall could happen few times during one trip !
Mechanic diagnosed battery was weak so it was replaced.
AIR FILTER was replaced.
MAF was replaced because of code P0101.
Problem is still there, its very dangerous specially when Im trying to make a left turn the car could stall on the middle of the road.
I have parked the car since its very dangerous to drive !
Any help is really appriciated.
Old Dec 16, 2023 | 10:38 PM
Do you mean Brake and Battery light? Or is it really the Brake and ABS light?
Aftermarket MAF or OEM?
Old Dec 16, 2023 | 10:50 PM
DEXT3R's Avatar
No battery light.
Its ABS & TRACTION light... my bad.
OEM MAF.
Ive been reading and noticed I never checked the pcv valve If its ORANGE and needs to be updated with a black one or it has nothing to do with this case.
Old Dec 17, 2023 | 10:36 PM
The only other clue you gave was that the battery was replaced. It could be to old age, but it also be because of a failing alternator. Have your alternator tested.
Check your Engine Coolant Temperature Sensor (ECTS). Follow the testing procedures in the Factory Service Manual (FSM).
Both can lead to stalling issues.
Old Dec 20, 2023 | 06:09 AM
LtLeary's Avatar
+1 with the Wizard. ODB2 codes would help but because you mentione MAF and PCV you may want to check out this thread as well. Trouble Codes P0171 & P0174 - Maxima Forums
NixMaxGLE
Apr 10, 2012 08:04 AM
04_Maxima
19
Mar 24, 2012 02:30 PM
MaximaMan
Dec 24, 2000 12:40 PM
