09 maxima p0430
Old Feb 2, 2024 | 03:18 AM
09maxima275's Avatar
09 maxima p0430
09 maxima 275k on the clock. Recently this code came up and I’m due for an inspection this month so I need to get this fixed. I believe this is a bad 02 sensor. If I am correct which one? Any help is appreciated. New to this.
Old Feb 2, 2024 | 08:12 AM
LtLeary's Avatar
I had to replace the cat (the one up front by the radiator) to get rid of this as I had replaced both upstream and down sensors to no avail.
Old Feb 2, 2024 | 09:34 AM
how many sensors are there total? This is the first ever front wheel drive I’ve owned not sure how it’s all set up.
Old Feb 3, 2024 | 07:40 AM
LtLeary's Avatar
4 total but be aware they are all different part numbers.
Old Feb 3, 2024 | 04:28 PM
So which sensors would I need to replace to hopefully clear the light? I’d like to try that before I replace the cat.
Old Feb 4, 2024 | 05:54 AM
LtLeary's Avatar
The ones labeled front!
Old Feb 4, 2024 | 02:46 PM
What size socket do I need to remove them? Gotta order one
Old Feb 4, 2024 | 05:28 PM
LtLeary's Avatar
I really dont recall. Over the years I picked up O2 socket sets and crows feet and just reached into the toolbox to find one that fit.
Old Feb 8, 2024 | 05:11 PM
So the sensors I need to replace are before and after the cat near the radiator?
Old Feb 8, 2024 | 05:29 PM
LtLeary's Avatar
No, but those are the one's YOU say you wish to change. I believe the Cat needs to be replaced . But it is your car and if you wish to replace those sensors, they are the ones for bank two! Pay attention to the part numbers!
Old Feb 8, 2024 | 05:36 PM
So you think the front cat needs to be replaced? Any cheaper alternatives? Just need to pass inspection
Old Feb 9, 2024 | 01:10 AM
q_nerk's Avatar
Is you need only to pass inspection you can do three things:
-just before inspection erase DTCs - it shoud be no check light for ca 10-15 miles, sometimes more
-install O2 sensor emulator for sensor after catalist - it a extension for o2 sensor mounting point - easy to buy on ebay
-use a obd2 DTCs eraser/cleaner
Old Feb 9, 2024 | 03:56 AM
I thought it took 50 miles or so for the light to clear on the computer. ?
Old Feb 9, 2024 | 02:09 PM
Mik2006's Avatar
you have to get up to like 65 mph and then slow down a couple of times as well. Not just drive 50 miles. I almost have the method down lol.
Sad to say but that code is a bad CAT no sensor...
Old Feb 12, 2024 | 04:25 PM
Can somebody post a link to the cat I need to order?
gelly42
18
Feb 26, 2014 06:04 PM
hornepirate
Jul 5, 2012 10:43 PM
MaxLoverAz
Jun 30, 2009 04:11 AM
indeep
Oct 8, 2008 07:57 PM
