7th Gen Fog lights for S model
Old Mar 29, 2024 | 01:24 PM
dgurule1991's Avatar
Hello everyone I currently own a 2013 Maxima S, it did not come with fog lights from the factory I believe as there are black plastic caps over where the fog light would be, I was wondering if I could have an auto body shop install this kit from Acanii that includes the assembly the wiring,switch and also the relay, here is the link https://a.co/d/aj9JHHX please get back to me asap, thanks
Old Mar 30, 2024 | 05:32 PM
Icecold's Avatar
I also have a 13 Maxima SV. I just replaced my fog lights that I ordered from Amazon AUTOWIKI Fog Lights Assembly For...
Amazon Amazon
the kit came with brackets, wires, and connectors. It may have a plug there without the fog lights being there. This set had everything needed. It was really easy to do but I did have to jack one side up to get under both sides. Direct fit too. Hope this helps
Old Apr 13, 2024 | 07:09 AM
William Driscoll's Avatar
I have a 2014 S model that I just put fog lights in and as another org member said that the fog lights wiring was there already installed! Mine was already installed also. So if you use the factory wiring you will have a cleaner simpler install. Good luck 👍
LorenzoMaxi
Apr 18, 2020 08:44 PM
Matto357
Oct 28, 2003 06:34 PM
perlmax90
Dec 17, 2000 09:43 PM
