what is the point of having fog lights?
Old Dec 17, 2000 | 11:33 AM
perlmax90
i was driving my moms 98 cutlas last night and there was alot of fog. so naturally i turned on the factory fog lights, and nothing happen. well nothing good at least. it made it harder to see. what am i surpose to be looking for when i turn on the fog lights? i'm under the impression that when you trun on your fog lights you can see through the fog. what do fog lights do if it doesn't make it so you can see through it?
Old Dec 17, 2000 | 11:57 AM
[s3]'s Avatar
Fog lights make your car look cool...thats about it
They are not really intended to cut thru fog, actually no amount of light will cut thru smoke/fog not even the sun.
The most prevalent use for them is so that your car is illuminated and people can spot your vehicle.
Old Dec 17, 2000 | 12:31 PM
2000MaximaSE's Avatar
Hey perlmax, how old are you. Just very curious...
Adam
Old Dec 17, 2000 | 12:37 PM
JDwyer2821's Avatar
If the fog lights are positioned right they are supposed to light up the ground so you can see the road better in front of you.
Old Dec 17, 2000 | 12:40 PM
JDwyer2821's Avatar
Also the make the car look a whole lot better
Old Dec 17, 2000 | 12:59 PM
perlmax90
so i'm surpose to be able to see the roade better
cool.
and 2000MaximaSE i just turned 18, why do you want to know?
Old Dec 17, 2000 | 02:49 PM
Like i said just curious, When i first saw you post on the board i assued you were in your 20's or somthing but after reading your posts i realized you were younger i was guessing 16 or somthing but i be wrong. Im 18 too by the way.
Adam
Old Dec 17, 2000 | 02:54 PM
perlmax90
and what is it about my posts makes
me younger?
just curious
Old Dec 17, 2000 | 03:52 PM
bl513's Avatar
FOGS:>>>>
my factory fogs with PIAA 85 watts in them light the road at least a 100% more than the headlights....9004 sucks!!
Old Dec 17, 2000 | 03:53 PM
tan_camry
fog lights, are supposed to be designed with a sharp cut-off (vertically) and put more light on the ground with the range of low beams and have a wider pattern. Many OE fogs are not designed so (hence your problem with the cutlass). Projector Fogs are the best type available.
What fog lights are supposed to do is, because of the sharp cut-off, it undercuts the fog (right above the ground), lighting up some of the road.
Driving lights (real driving lights are mounting above the bumper), illuminate further and lack the sharp cut-off of foglights, and have a narrower beam pattern. But you can mount them like fogs, and sort of have the best of both worlds. I personally have PIAA 1253 driving lights. I barely have a problem fog (except for the super dense fog where my low beams are blinding me).
Unfortunately, a lot of people do by them for looks (it's their money...not complaining), and make it worse by using SW and blue bulbs.
tan
Old Dec 17, 2000 | 09:43 PM
speedracer's Avatar
yeah fog lights are not for the purpose of making the car look better or makin gother cars see u better, its for the road... when your fog lights are on, it illuminates the road better ... when there is fog, you cannot see the ground that well and the fog lights help light up the ground better so u can see where u are going better.. it doesnt really make way for the path u are following, it doesnt better your view at eye hight, but the ground is beter seen.
The Frye
Sep 2, 2021 11:03 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
