Road Noise / Call Audio Complaints?
Does anyone else have problems with road noise at highway speeds?
I personally thought it was a little loud and have received several complaints about the background noise on calls while driving on the highway.
The biggest factor in road noise is of course the texture of the road surface. I've found that certain states and even some counties within states use a coarser road material, either for cost reasons or for durability. Those coarse materials make for a real road howl. And where grooved pavement is used, it ups the ante even more.
Areas where asphalt is used have super-quiet roads, but we can't have them everywhere.
Yes - in fact, that is my only serious gripe. I actually paid to put different tires on after only 700 miles. It helped a little, but not a lot. It does seem to be very dependant upon the different road surfaces. Several times I have been driving out of the neighborhood in the morning, and I find my self checking to see if a window is partially rolled down. Seems worse from passenger side than drivers'.
I have wondered if I have some mis-sized or mis-shapen weather stripping.
I will add that my wife's 2007 $20K Frontier has considerably less tire noise than my Maxima, with truck/SUV tires.
SR has more road noise for obvious reasons.
Originally Posted by akin_t
Do you have an SR?
Go back to the dealership you bought your Max from and ask to drive one of their Maxs to see if it has the same noise issue. They shouldn't mind helping you out and if they do, you need to find another dealership to give your business to...
Guess the noise issue is relative to the road surface. Compared to our 2013 ILX Tech, the Maxima is very quiet, like night and day!. If you need to do something, try some insulation under the back seat and trunk area. I have used FatMat with great results in the Acura. Reasonably priced. There are other types I'm sure you will hear about right here.
http://www.fatmat.com/
Same sound here, it sounds like a window is cracked open.
Don't know if there is a way within the head unit itself. From an Infinity forum, they said there is no way to turn off (but this is in an infinity). They also said it is not active if a door is open. They suggested, leaving a door closed but ajar so as to keep it off.
The other potential option is to find the fuse for the head unit and remove it. Since the ANC runs through the speakers, cutting power to the amp would kill the ANC.
Best of luck
Disclaimer: I'm not a mechanic and far from it. Do not remove fuses unless I are sure it is safe.
Best of luck
From another user on another thread:
I hear you can turn of the ANC by
1) turning off audio system,
2) hold down the menu button and turn the volume button.
This brings up the secret menu where you can disable it.
I have the same issue but mine also sounds like the doors are opened a little.
Totally a road surface issue for me. Normal Georgia road? Cannot carry on a conversation with my wife two feet away. Freshly laid asphault? My wife and I can carry on a conversation by whispering.
jim84
11-07-2005 05:03 PM
