Sub and Amp in 2016 Maxima question
Old Nov 12, 2015 | 08:57 PM
desertbrown27's Avatar
Hey guys I'm new on here but I am putting a 12" Subwoofer and a 1000watt amp in my maxima SL with Bose audio System. After the shop installed it I am get a ton of feedback. they have used different parts, moved the jacks, but nothing will get rid of the feedback. It will happen while idle, when I push the gas. Will stop if I open a door or put the windows down. Has anyone had this problem? Been looking online but haven't found a maxima with a bass system yet. Help
Old Nov 12, 2015 | 10:50 PM
wtgkb8's Avatar
Could it have something to do with the Active Noise Cancellation which is standard on SL and above trims? I'm not sure of all the details on how this works other than it uses the Bose audio system and speakers to eliminate unwanted noise. Maybe this is deactivated when the door or window is opened...but I don't know for sure.
Old Nov 13, 2015 | 08:05 AM
mrbtjohns's Avatar
Maybe it is not grounded properly???
I have a JL sub and woofer in mine (Platinum) and I do not have any feedback issues...
Old Nov 13, 2015 | 09:00 AM
spidgeon's Avatar
Yeah sounds like a grounding issue to me. I would bring it back to whoever installed and have them fix. If they can't, you may want to get a second opinion from another audio dealer / installer.
Old Nov 14, 2015 | 05:12 AM
kaulana47's Avatar
I talked with a car audio shop a few weeks ago and they said cars with active noise cancellation (ANC) can get false correction when adding a sub. Most systems allow the user to turn off the ANC. Look in the manual to see if you can turn it off. If it sounds better... that's your answer. If not, it is likely a grouding issue.
Anyone know if the ANC will work when modding the engine (intake, exhaust, etc.)?
Old Dec 23, 2015 | 06:00 PM
16sjmax's Avatar
Just had my amp and sub installed tonight and the active noise cancellation reared its ugly head. My shop needs to find out how to disconnect/deactivate the interior microphones. They said the have seen this this on several luxury models, but did not have the maxima specs readily available. I need to give them a few days with Christmas upon up to get the specs. I'm am not worried, yet...
Old Jan 19, 2016 | 08:41 PM
Found out how to stop the feedback without disconnecting the noise cancelation mics.
http://www.moodym.com/articles/diag/hidden-diag.shtml
It does work I went back to the dealer a drove a base model maxima to get an idea of the difference when I was thinking about disconnecting the mics then someone posted this on facebook. I turned the cancelation system of and drove around a little and the difference is not really noticeable. My 12s work perfect now
Old Jan 19, 2016 | 10:14 PM
cstrasz's Avatar
So to install an aftermarket sub and amp you have to disable the noise cancellation in some cases? That's a shame. Seems like it would cause more road noise inside the cabin.
Old Jan 19, 2016 | 10:17 PM
Its not much of a difference plus if your putting subwoofers in your car when are you going to really hear road noise?
like putting mudding tires on a truck and not wanting to get them dirty with mud.
Old Jan 20, 2016 | 04:49 AM
Frasierts's Avatar
I heard from another user on here:
1. Turn off your radio
2. Press and hold the "Menu" button while spinning the volume button
3. Scoll down to ANC ANS feature.
I have done this and will be installing my amp and sub soon as well. Hope this actually helps.
Old Mar 26, 2016 | 12:27 PM
Lord Yok's Avatar
Hey did u ever get around to installing the amp and sub. I'm planning on doing the same, just trying to collect some notes.
Old Mar 27, 2016 | 07:15 AM
lowriderman3's Avatar
Good info to know as I am about to get to this point too.
Old May 7, 2016 | 06:32 PM
ZroSkil's Avatar
Great info, thanks Frasierts.
Old May 9, 2016 | 11:31 AM
Frasierts's Avatar
I did and it worked. I installed everything, forgot to turn the ANC off and heard that horrible feedback. Immediately turned it off and it is fine now.
Old May 9, 2016 | 08:01 PM
You turned off the ANC through the secret menu?
Old May 18, 2016 | 09:08 AM
corpdecker's Avatar
Yep, I installed a JBL self powered sub enclosure in the trunk and I have to disable the ANC every time the battery is pulled or fuse blows, as it is enabled by default. Without disabling it, the sub goes ape**** even without the radio on. I tested it out several times but couldn't tell any perceivable difference between having it on or not, especially if there is any other sound in the car like the radio.
Old Jun 16, 2017 | 03:13 PM
chasewen's Avatar
Line out converter
I'm having a hell of a time with this little box..... Everything is hooked up and this box is kicking my ****. Where did you/y'all install yours?
Old Jun 17, 2017 | 12:37 AM
Derichio02's Avatar
I'm also about to tackle this. I'm thinking of wiring the line out converter in the trunk but not sure if I should do it before the factory Bose amp or after. If before, anyone know the colors for the +/- and L/R at the amp
Old Jun 22, 2017 | 12:26 PM
corpdecker's Avatar
Here's some pics of what I did.. note I tapped the speakers directly, the bose system uses weird voltage for their speakers and such, so I put it behind the amp.
Drilled a hole there for the ground (black wire with yellow near tip)
Old Jun 22, 2017 | 02:32 PM
FattiesGoneWild's Avatar
Might be a dumb question but instead of making a new thread. Does the stock Bose sound system in this car include a factory sub hidden some where?
Old Jun 22, 2017 | 02:49 PM
corpdecker's Avatar
Nope, no sub in any models
Old Jun 22, 2017 | 05:33 PM
Ah that is a bummer. What is so premium about the factory sound then? Just because it says "Bose"?
Old Jun 22, 2017 | 07:57 PM
Gator5000e's Avatar
Nothing premium about the Bose system compared to what I've heard in other cars with premium sound systems. The Bose system is my biggest disappointment with the 2017 Platinum.
Old Jun 28, 2017 | 07:12 PM
MelodicMurder's Avatar
JL Audio 10" Sub, Amp and Box.
I'm still disappointed with the Bose system but the sub has helped a lot.
Next on my list is a new Tesla style stereo with RCA outputs.
Old Jun 28, 2017 | 11:37 PM
Derichio02's Avatar
What color are the positive and negative wires at the rear speakers. Is there a wiring diagram. I'm going to tap in at that point to feed my line out converter.
Old Jun 29, 2017 | 06:58 AM
Gator5000e's Avatar
All that stuff is way over my pay grade!! Looks bad *** though. But in all honesty, what does having the sub woofer do for the overall sound of the system since it seems you left the original Bose speakers in place.
Old Jun 29, 2017 | 10:49 PM
Derichio02's Avatar
Bump for the +/- wiring for the rear speakers in the Bose system. I'm gonna tackle installation this weekend.
Old Jul 23, 2017 | 03:17 PM
Jewan Roopnarain's Avatar
Thumbs up
i have the 2017 SL and my Premium Bose sound is amazing..
Old Dec 20, 2017 | 11:53 AM
maximaman79's Avatar
Hey where did you guys run the power wire through the fire wall? Any one have pictures and location? Thanks
Old Dec 20, 2017 | 02:53 PM
I followed the wire from the hood release lever. It goes behind the drivers side front tire. You have to take the plastic wheel well off to snake it through.
Old Dec 20, 2017 | 08:44 PM
svtcop's Avatar
If you remove glovebox there is a grommet up and slight right that passes through the firewall. There was a thread on it but I can't seem to find it. If you search 7th gen it's in the same spot. Kind of a pain to get up in there if you're a bigger guy but that's where I ran my 4ga, probably won't get any thicker wire through there though. Wasn't too hateful, just will use a bit extra wire running it through eng. compartment to battery on drivers side.
Old Dec 20, 2017 | 10:24 PM
Which side is best to run the power wire driver or passenger side. ? Also where is a good place to get amp turn on?
Old Dec 21, 2017 | 05:36 AM
MadMax07SL's Avatar
Get you one of these, you don't need a remote turn on wire. This LOC will sense speaker signal then activate it's own remote on to hook up to the amp. Best LOC I ever purchased. Actually used it to replace a cheap $15 one I had that lost a channel. Sound quality went up about 3X in my layman opinion. Same amp, same woofer, considerably more/clean punch. Seriously the best piece of gear I've ever used.
Linky:::
Amazon Amazon
Old Dec 21, 2017 | 05:44 AM
MadMax07SL's Avatar
BTW, that LOC does require power too, but you just run a thick line to the AMP from the battery, run a smaller gauge wire from that power connector on the amp to the 12v on the LOC, and of course ground both. Then leave the "remote In" on the LOC empty, just run another smaller gauge wire from the "remote out" to the remote on at the amp. When the stereo goes off the amp shuts off in maybe 3-5 seconds after. I was floored how nice that was, 30 years of putting bass in cars, I can't believe I never went this route. It was a "where have you been all my life" moment, good thing I was alone...
Edit: Oh, and Instant on too...it's not like you get all the highs then the bass kicks in a few seconds later, by the time the radio is playing, bass amp is already on.
Old Dec 21, 2017 | 09:18 AM
Linky:::
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Yep this is the one I’m using. I’m helping out a guy I know down the street with this install. I usually never use LOC, but I know this one is pretty good. I think I’m going to run the power wire on the glovebox side. Just need to remove it now to get the grommet.
Old Dec 26, 2017 | 03:44 PM
I decided to run the power wire on battery side and worked out well using an
existing grommet. The new sub sounded great using the audio control LC2i.
Was able to retain most of all trunk space also.
Old Dec 27, 2017 | 06:02 AM
MadMax07SL's Avatar
That's a clean job! What enclosure is that?
Old Dec 27, 2017 | 08:51 AM
It’s a custom built enclosure I built from fiberglass mold. I took a mold of the left side of the trunk area.
Old Dec 28, 2017 | 07:24 AM
MadMax07SL's Avatar
If that thing sounds as good as it looks...damn!
