Weird issue with left license plate light going in and out
Feb 23, 2016 | 07:43 PM
So i've had two of my friends on separate occasions tell me that my left license plate light was going in and out. The 2nd friend / the 2nd time, he ended up recording it while he was following me so I could see the issue. The first time was before I had replaced the stock halogen bulbs with LED so it leads me to believe there's some sort of wiring or electrical issue vs the bulbs I put in. What's odd is that it's very intermittent and not predictable at all. It does happen when the blinker isn't on as well. I would assume it can't be the fuse if it's working at all, so I'm at a loss here. Has anyone else experienced this or heard of this issue? If I can't find any help here, I may have to just take it into the dealership for them to look at it.
Feb 24, 2016 | 05:57 AM
had that issue, but maybe with different led bulbs...
i the exposed chip style at first, which blinked a lot here in san francisco/bay area weather.
then, i switched to an encased type, and it does not blink anymore.
(hope photos do post)
Feb 24, 2016 | 06:09 AM
Hmm well as I was stating before, it happened with the stock halogen bulbs too. I suppose I will try stock again just to be certain.
Feb 24, 2016 | 10:07 AM
Check the metallic connections on both types of bulbs, its possible (not likely) that both bulbs happened to have bent contacts that weren't making a good connection, but it sounds like there may be an issue with the socket itself.
Feb 24, 2016 | 09:46 PM
ah, yes. i misread the whole passage.
i second Clouded's analysis on the metal contacts thingy.
or, you just happen to have bad bulbs.
hope you find the fault.
Mar 1, 2016 | 09:32 AM
These are the ones I bought so I put the stock halogens back in for now. Apparently when I had someone follow me, stock halogens are fine so perhaps you were right. However, these that I purchased seem to be the enclosed type and I still had the blinking/flashing issue at random times. Not sure what to replace these with now.
Amazon.com: JDM ASTAR Extremely Bright 5730 SMD 194 168 175 2825 W5W T10 LED Bulbs,Xenon White: Automotive Amazon.com: JDM ASTAR Extremely Bright 5730 SMD 194 168 175 2825 W5W T10 LED Bulbs,Xenon White: Automotive
Edit: Going to give these 6k bulbs a shot instead
Amazon.com: Philips 194 Bright White Interior Vision LED light, 2 Pack: Automotive Amazon.com: Philips 194 Bright White Interior Vision LED light, 2 Pack: Automotive
Mar 1, 2016 | 10:00 AM
Quote: These are the ones I bought so I put the stock halogens back in for now. Apparently when I had someone follow me, stock halogens are fine so perhaps you were right. However, these that I purchased seem to be the enclosed type and I still had the blinking/flashing issue at random times. Not sure what to replace these with now.
The Philips ones are the ones I installed and they have been working without any issues.
Mar 1, 2016 | 10:48 AM
I installed the door panel, backup lights and license plate lights
All from dynamic diode and everything works great.
70 bucks for all the lights replaced
Just my 2 cents
Kevin
