Spoiler from spoiler king
Old Apr 23, 2016 | 07:41 AM
BlackMambaSV's Avatar
Has anybody ordered a spoiler off amazon from spoiler king? Just wanted to see some pictures and how does it differ from OEM?
Old Apr 23, 2016 | 04:31 PM
DarkSlate's Avatar
Just installed mine today. It's actually a big piece of rubber that needs to be painted with flex paint and bent to be installed. Was a pain. I'll post some pics tomorrow after I take the tape holing it in place off. I like it better then oem. But hate the paint job the shop did so now that it has paint on it will get it wrapped in gloss black.
Old Apr 24, 2016 | 09:51 AM
DarkSlate's Avatar
Here are some pics
Old Apr 24, 2016 | 06:46 PM
Could you please send a copy of the link from where you bought it?
Old Apr 24, 2016 | 07:49 PM
DarkSlate's Avatar
This is the one I got.http://www.amazon.com/gp/aw/d/B016NB...maxima+spoiler
I would also recommend cleaning the area really well, scuffing the clear coat with a scotch guard pad and using 3m adhision promoter. Will help it form a strong bond so it won't fly off on the highway. Here is the link for the adhision promoter. http://www.amazon.com/gp/aw/d/B004TG...WvL&ref=plSrch
Old Apr 26, 2016 | 07:21 AM
Darren Fahnestock's Avatar
I ordered directly from spoiler and wing king. Mine is fiber glass and painted. Ten dollars cheaper than amazon. Looks like high quality. I will post a pic when I get a chance. I have to put it on this weekend.
Old Apr 26, 2016 | 07:47 AM
http://spoilerandwingking.com/2016-N...-STYLE-SPOILER
Old Apr 26, 2016 | 08:50 AM
DarkSlate's Avatar
Originally Posted by Darren Fahnestock
I was looking at factory style ones but for some reason I did not like the look so went for a different style. For the one u ordered u will have to drill the trunk to install.
Old Apr 26, 2016 | 10:03 AM
mpbclutch33's Avatar
Don't both of these have to drill holes?
Old Apr 26, 2016 | 10:26 AM
JSROOKS's Avatar
I would think because over time 3M tape and adhesive isn't going to cut it and it will fly or fall off.
Old Apr 26, 2016 | 12:43 PM
DarkSlate's Avatar
Should last for a couple of years. I used the 3m adhision promotor. This is stuck on there really good.
Old Apr 26, 2016 | 01:22 PM
JSROOKS's Avatar
I would want something a little for secure with screws because the Arizona sun in my state will eat up the 3M quick.
Old May 2, 2016 | 12:40 PM
DbrainX's Avatar
Did you need to drill holes? (it says so on the item on Amazon) Ive been wanting to pick it up.
Old May 11, 2016 | 07:26 PM
Could you tell me how you installed it? Wanna know how hard it is before I buy
Old May 28, 2016 | 07:50 PM
Christopher Stark's Avatar
Guys does the '16 SL come with the wiring already under the trunk hood to be able to have both rear window AND spoiler light on at same time?
Old May 29, 2016 | 09:21 AM
DbrainX's Avatar
Normaly they arent prewired but you can buy the 3rd light delete for behind the backglass if you dont want a 4th light from Nissan but it isnt always cheap
Old May 30, 2016 | 01:50 PM
Stlbluzoo11's Avatar
Are you saying that you did not drill holes on the trunk lid? You used the adhesion promoter and 3M tape and have no issues? I would be interested in this option. How has the wing held up since install?
Old Jun 15, 2016 | 02:14 AM
deerram's Avatar
I just installed a spoiler from Spoiler King on my Forged Bronze SR. Its the same one that comes on the SR model. Fit great, perfect finish. Color is almost identical to factory and the average Joe won't notice. Since I have done lots of paint work I did notice a slight difference in the metallic size but that's all. You do have to drill 4 holes to mount it and one for the wires. I wired mine to the drivers tail light as it was easier to access than the factory 3rd brake light.
Old Jun 30, 2016 | 05:39 PM
pvresale's Avatar
I installed a generic one off ebay. Looks like the wing king one pictured above. Color match was excellent and installation was similar to ones Ive done before. Mine came with 4 plastic guiding strips for hole line up and drilling. Needed 5 so I made flat one out of card stock. I always surround the hole electrical tape as an added measure to reduce damaging the surrounding area before drilling. Once all holes are drilled (5), I used touch up paint and clear nail polish to reduce any rusting. For wiring I clipped the led connector that is normally used for the oem spoiler and connected the blue to the red and gray to the black wires. Beware, the nuts on either end of the wing are always a pain in the you know what to get in. You may have to drill 2 larger holes if you have difficulty using your hands or rachet. I alway have a 1" metal drill bit handy just in case I need an opening. If you get any random metal bits stuck in between the lid, cover the bottom holes with tape leaving one of the larger ones open. Take a vacuum and suck out any metal flakes from drilling. Do the same to the other side.
Old Jun 30, 2016 | 05:44 PM
raven69david's Avatar
Do you have a link to the one you ordered? Can you also post a few pictures of it? TIA
Old Jul 1, 2016 | 07:42 AM
pvresale's Avatar
http://www.ebay.com/itm/161972491686?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Attached Thumbnails Spoiler from spoiler king-img_20160701_100800.jpg   Spoiler from spoiler king-img_20160701_100807.jpg   Spoiler from spoiler king-img_20160701_100827.jpg   Spoiler from spoiler king-img_20160701_101130.jpg   Spoiler from spoiler king-img_20160701_101105.jpg
Spoiler from spoiler king-img_20160701_101228.jpg   Spoiler from spoiler king-img_20160701_101446.jpg
Old Jul 1, 2016 | 07:58 AM
Thank you so much. Does it connect directly to the existing plug or does it need to be modified like yours?
Old Jul 1, 2016 | 08:08 AM
pvresale's Avatar
The generic spoiler comes with two bare wires you have to connect. I cut the wires from the led connector that was connected to the interface in the picture. If you buy an oem spoiler there is no cutting as both connectors would fit together as intended. The wiring is the easiest part. Drilling and getting the corner bolts are what takes time.
Old Jul 3, 2016 | 10:01 AM
groovyv03's Avatar
Pre Wired for Spoiler
Hey Chris, I too have an SL and it DOES have the Brake wire ready for spoiler.
I took the trunk liner off to check because I will be installing a spoiler a soon as I decide if I want to buy OEM for $308 OR Ebay aftermarket for $100 or so
Christopher Stark;9111967]Guys does the '16 SL come with the wiring already under the trunk hood to be able to have both rear window AND spoiler light on at same time?[/QUOTE]
cdoublejj
Apr 21, 2016 01:46 PM
waylouderthanyou
Apr 15, 2016 12:01 AM
ndtony
Apr 4, 2016 08:46 PM
mclasser
Mar 27, 2016 04:08 AM
