Closest 12v Switched wire by front dash
Old Nov 11, 2016 | 07:47 AM
mack4477's Avatar
Looking to hard wire install a Valentine One and a dash cam in my 2017 Maxima SR. Any ideas on the best and easiest place to look to do so?
Old Nov 11, 2016 | 10:51 AM
Do you know about Valentine1's Savvy accessory? Besides muting the V1 at low speeds where you won't get a ticket, it will power the V1 through the OBDII port.
https://store.valentine1.com/store/
Otherwise, run the wire from the V1 by tucking it behind the headliner, down and behind the A pillar, and to the fuse box. Get power using this:
https://www.amazon.com/Pico-0956PT-B.../dp/B001QRSBW0
Just don't use a fuse that has constant power, only one that energizes when the car is running.
Old Nov 11, 2016 | 11:34 AM
mack4477's Avatar
Not a bad idea with the fuse holder. Thank you for the idea
Old Nov 12, 2016 | 12:58 AM
Jeeper31's Avatar
Tap into the mirror. Look at a blend mount.
Old Nov 12, 2016 | 05:19 AM
mack4477's Avatar
I'm not sure what you mean by blend mount?
Old Nov 12, 2016 | 05:27 AM
Jeeper31's Avatar
They have very good mounts and wire taps. I tapped right into the back of my mirror for radar detector power. Easy!
http://blendmount.com
Old Nov 12, 2016 | 06:02 AM
mack4477's Avatar
Those look awesome. I will have to go out and figure which mirror I have now. Thank you sir
Old Nov 12, 2016 | 06:14 AM
Jeeper31's Avatar
Old Nov 13, 2016 | 09:03 AM
Frasierts's Avatar
I used Blendmount as well for my Valentine1. I got the wiretaps and the rearview mount. I love the look being close to the mirror and how easy it was to install.
