Parking aid range question.....
I seen in the user manual it says Near/Mid./Far I have it on the factory setting which is set to Mid. I don't like it since it seems it waits to long to sound off when you get close to something. I want it more sensitive then that. But not sure which one to pick Near or Far? Maybe I am not understanding how the system works correctly either? We came from a 2015 Chevrolet Impala 2LTZ and it was very sensitive when getting close to things. This Maxima is not like that which leads me to believe its a setting I am missing some where.
I haven't actually done a test to confirm, but my interpretation is that "far" would mean detect objects farther away. That's where I have mine set. I can tell you it goes off pretty much every time I go through a drive-thru. LOL
Sounds right. I changed it to far the other day and its much more sensitive. The only thing is when you hear it going off from the front while moving forward. You have to hit the camera button to see where its coming from. Unless I am missing something to do it automatically by switching to the camera to show you?
Can someone please test this driving forward to see if the camera goes on automatically or not? Or do you just get a beep? I cant recall myself if it does this or not and since they changed the whole head unit. I don't know if its working right or not.
***EDIT***
I found a test dummy to use and it works while in drive with the brake on. I did not have enough room to test while rolling and will try another day.
***EDIT***
Okay this is weird and I still need to know if its working as designed. I was backing out yesterday from a parking space at the store. Put it in drive and was turning my wheels to the left. There was a car in front of me as well. All I got was beeping and no camera for a visual to see what censor was being triggered up front. Is this normal with the camera not kicking in showing you?
