2017 Maxima Radio Issue Help
Old Dec 5, 2019 | 12:56 AM
Joselynn26's Avatar
Hi everyone- I own a 2017 storm blue maxima that I love, however a week ago while driving the radio shut off then rebooted and turned back on with no error messages or anything. Then it started doing the same thing again every 5 minutes. Even if I turned the radio off and just view the map it would still shut completely off and turn back on. I called the dealership and took it in. I have 42,000 miles on it so it’s out of warranty. They said it would be 149.00 to do a diagnostic check- I think that’s nuts so I said I’d come back. Now 3 days later it completely stopped working, doesn’t even power on, nothing on the screen or anything but it lights up just a tad. And even the usb charging ports aren’t working. Can this be as simple as a blown fuse? I don’t want to spend 149 for them to replace hopefully a 20.00 fuse. Would autozone be able to help me?
Old Dec 5, 2019 | 08:41 AM
effinaround's Avatar
Intermittent power connection? Maybe check the fuse box and reseat the fuse. Failing that, try a third party car audio place as they might not charge as much to look at it.
Old Dec 5, 2019 | 08:53 AM
dmstangu's Avatar
Turn the car off. Open the fuse box to the left of the steering wheel. In the middle, there should be a big white plastic square. It's the shipping and storage mode switch. Pull on it gently and it should pull out a couple millimeters. Wait some 30 seconds, then push it back in vigorously. Turn the car on and hopefully your problem is solved.
Old Dec 10, 2021 | 08:58 AM
Candace Turney Reagan's Avatar
Whatever came about your problem
I am having the exact same problem with my 2017 Nissan Maxima with 40,000 miles. My radio is now completely dead. Just wandering if you found the fix on this problem.
Old Dec 11, 2022 | 07:47 AM
Rob Garcia's Avatar
Problem
I'm also having the same problem on my 2017 maxima and it has 104,000 miles
Old Dec 12, 2022 | 04:30 AM
RickSmith's Avatar
Replacement radio is the answer, aftermarket or OEM, your choice.
bolido2000
Sep 13, 2021 11:55 AM
Aburn95
Aug 18, 2013 11:39 AM
Hurricane434
Oct 6, 2008 05:24 PM
hoosier
May 23, 2002 09:16 AM
