Replace Brake Fluid at 20k
Old Apr 27, 2020 | 03:06 PM
Wisenheimer16's Avatar
Is anybody really replacing the brake fluid every 20k like the manual suggests?
Old Apr 27, 2020 | 03:35 PM
compyelc4's Avatar
Not here and I'm at 24,000mi. I probably won't consider doing this until around 100k, if I haven't grown tired of the Max, and at this point she still seems new and exciting to me. I usually go by time and not miles. The only car I have ever owned that I changed brake fluid in is my '95 Corvette, and she has 65,000miles. Fluid still looked new and she braked just fine. Go figure.
Last edited by compyelc4; Apr 28, 2020 at 07:37 AM. Reason: chgd 42,000 to 24,000. Oops.
Old Apr 27, 2020 | 05:34 PM
2young2retire's Avatar
I broke down and had it done by a local brake shop at the 20,000 mile mark. He used a vacuum pump setup to suck out the old fluid and the new fluid in. My bad for not taking pictures of the old fluid as it was a lot darker than I thought it would be. I think it was around sixty bucks or so. With all the plumbing for the automatic braking I thought I would be on the safe side. I didn't flush the fluid in my 2009 Max until around 80,000 miles.
Old Apr 28, 2020 | 04:34 AM
Thank you for your replies.
Old Apr 28, 2020 | 07:39 AM
compyelc4's Avatar
I'm so f'ing cheap. You probably did the right thing and will be better off for it.
Old Apr 28, 2020 | 08:33 AM
robtroxel's Avatar
I'd do it sooner than later because the brake fluid attracts moisture and therefore will cause the system to degrade later in the cars life. You can have the existing fluid "PH" tested. Since you are under warranty for the 1st 36 months/36 K I'd do this so the dealer can't deny any possible repair costs down the road.
Amazon Amazon
Old Apr 28, 2020 | 11:56 AM
lionel2013's Avatar
I just did, a couple of days ago.
Pnjboyzz
May 12, 2014 06:04 PM
flthere
Fluids and Lubricants
37
Oct 3, 2005 08:34 AM
aussie983
Mar 24, 2004 11:08 AM
