Need help wheels poke out too far
Old May 27, 2020 | 07:26 PM
Skiver's Avatar
Looking for flush fitment. Car is not lowered yet. Running 20x10 ET25 square set up. Need advice for flush stance on 2016 maxima platinum
Old May 27, 2020 | 07:47 PM
Les7311's Avatar
Only thing I know is to get new rims.
Old May 28, 2020 | 03:59 AM
kasdepwel's Avatar
What kind of help do you expect?
I run 20X9.5 40 offset and it's really flush. I'm also lowered.
Old May 28, 2020 | 04:52 AM
Skiver's Avatar
Do you think if I lower the car and pull/roll fenders it will alleviate the poke?
Old May 28, 2020 | 05:00 AM
kasdepwel's Avatar
unless you run a lot of camber and roll the fenders you won’t fit em. What size tires do you run
Old May 28, 2020 | 05:02 AM
Skiver's Avatar
can you post pict with your set up
Old May 28, 2020 | 05:03 AM
Skiver's Avatar
wrapped in Falken 255/35/20
Old May 28, 2020 | 05:04 AM
kasdepwel's Avatar
Old May 28, 2020 | 05:07 AM
kasdepwel's Avatar
I also run 255/35/20 since a few weeks and and they rubbed while my 245 did not. I had to put some camber to clear fenders until I have em rolled. With my 245 I was at factory specs with alignment and I was dead flush up front but could have used a 5 mm spacer on the back.
Old May 28, 2020 | 05:13 AM
Skiver's Avatar
pretty clean fitment. I was looking for a deep concave look going with the Rohana RC7s but they poke too far out. So basically I am going to order new wheels again. I can probably keep the tires and just order wheels. Are you sitting on Eibach springs?
Old May 28, 2020 | 08:30 AM
Lower car with a little camber and a roll and/or pull. Should be fine.
Old May 28, 2020 | 08:53 AM
lindros2's Avatar
1. wheels are too wide ("rims" for those nitpicking).
2. tires aren't wide enough for the wheels - you will destroy them.
Start over. Wrong setup for your car, period.
Old May 28, 2020 | 08:59 AM
Skiver's Avatar
I was thinking I would have to send them back but if you feel i can add a little camber roll/pull fenders and lower they will fit better than what you see.
Old May 28, 2020 | 09:02 AM
Skiver's Avatar
told seller I was looking for square set up and a flush fitment and they said this will work. After mounting there was about flush
Old May 28, 2020 | 10:16 AM
compyelc4's Avatar
Take them back and get something that is more flush. You WILL have problems with these wheels. If you insist on using these your setup will look ridiculous getting the clearance you need. No matter what you do with those wheels to get clearance you will get major curb rash. Just my thoughts.
Old May 28, 2020 | 10:34 AM
Skiver's Avatar
Called Rohana and they said I can run a 45 offset in the front from the current 25 offset. If this works I will out the cost for another 2 wheels instead of 4.
Old May 28, 2020 | 05:21 PM
You’ll have to make sure wheels will clear the suspension with that higher offset.
Old May 29, 2020 | 09:12 AM
robtroxel's Avatar
You should try that. Can you conditionally try the 45 offset wheels to be sure? Glad you have a Platinum with the 360 view/curb cams. At least you can see possible damage before it happens. Good luck
Old May 29, 2020 | 09:29 AM
Skiver's Avatar
If the 45 offset does not work, I will be starting over with a new wheel and fitment. Then I will have to unload these 20x10 Rohanas.
Old May 29, 2020 | 09:39 AM
Prophecy99's Avatar
do your homework before buying....
Old May 29, 2020 | 09:43 AM
BlakMaxiJoey's Avatar
front 20x9.5 +40 @245 wide (+35 to +38 might be more flush with the fender)
rear 20x10.5 +45 @275 wide (with fender rolled to about 45 deg)
Old May 29, 2020 | 09:58 AM
Skiver's Avatar
The help is much appreciated to everyone.
Old May 29, 2020 | 12:02 PM
robtroxel's Avatar
Sorry, the 1st set did not work out. Someone will buy them. Meanwhile, keep us posted on what you do
Old Jun 11, 2020 | 09:55 PM
414sfinest's Avatar
His wheels/rims aren’t to wide. He just has the wrong offset. And I’m not talkin’ about the rapper from the Migos. See what I did there... rapper guy same name as car stuff... ah forget it. Any woo, it’s all with your offset. I believe it was @BlakMaxiJoey who put it best... if you’re running that 20x10 and want it flush you need a higher offset. I’d say +38
40 would put you where you want to be. But I also didn’t see what tire size you were running as well. I have 22x9’s +38 and I’m a **** hair from being flush.
Old Jun 12, 2020 | 04:56 AM
lindros2's Avatar
Dude the actual rim inside the tire is too wide.
I've dealt with this before.
All the offset in the world can't overcome stupidity.
But it's his car.
Old Jun 12, 2020 | 06:43 AM
414sfinest's Avatar
But it's his car.
well out of your comment you got one thing right... it’s his car. Yup this is correct.
And thank you so much for clearing up what the “actual rim” inside the tire was referring to as in the wheel... no **** Sherlock. And stupidity? On who’s part? The gentleman asking for help? Because as he states he asked someone he thought was knowledgeable in what we was looking for but clearly didn’t. Again, stupidity of someone like @BlakMaxiJoey because he has a staggered setup that’s running a 20x10.5 and fitting flush? Or stupidity on behalf of all the other guys on this site running 20x10’s+ squared with no issues? If anything he should have done maybe just a little more homework and searching on this site first and he would have gotten his answer.
Old Dec 28, 2024 | 12:25 PM
JayBoyd1111's Avatar
Is your car lowered and what is your rim specs ??
Old Dec 30, 2024 | 10:34 AM
Maxcar's Avatar
[QUOTE=kasdepwel;9222619] Beautiful. What color is that?
gtr_rider
Tires and Wheels
Jun 21, 2003 02:34 PM
