2018 SL - can't remove Pre-Set radio stations
Old Feb 25, 2021 | 04:53 AM
blkatt's Avatar
Question 2018 SL - can't remove Pre-Set radio stations
Here's the deal. I can create a pre-set radio stations no problem. However, there seems to be no way to delete/remove them. I tried removing the battery cable - stil there. These are regular radio staions - not SiriusXM. I also tried the invoking the battery saver fuse , pre-sets still there. This is weird. And Nissan has NO documentaion on this. Any assistance is appreciated.
Old Feb 25, 2021 | 11:05 AM
blkatt's Avatar
It makes sense Nissan doesn't offer documentation on deleting presets. They don't have a way of doing it. Oh well.
Old Feb 25, 2021 | 02:27 PM
robtroxel's Avatar
Warranty? Isolated incident?
Old Feb 25, 2021 | 03:17 PM
blkatt's Avatar
Out of warranty unfortunately. Not isolated.
Old Feb 25, 2021 | 03:41 PM
You may not be able to delete presets, but surely you overwrite the presets. Sounds like the factory gives you say 10 presets (random number chosen), and you may only want 5, but when you cycle through your presets using the controls on your steering wheel, you're stuck with cycling through all 10 presets. Is that the gist of the problem?
I assume you have checked your owner's manual?
Old Feb 25, 2021 | 03:47 PM
Richard66's Avatar
Must be some way to do a radio reset. This should get rid of them.
Old Feb 25, 2021 | 04:00 PM
blkatt's Avatar
Correct . I can overwrite existing presets, yet can't delete any existing presets. I've never seen such a thing before. The owner's manual offers no guidance.
Old Feb 25, 2021 | 04:09 PM
blkatt's Avatar
I investigated the radio reset route to no avail. I thought about "unlocking" the SD card - I just don't want to corrupt the card. Yet, when I bought the car second hand, it lacked an SD card. Even without an SD card, deleting presets was impossible. Thanks
Old Feb 25, 2021 | 06:57 PM
Richard66's Avatar
If you disconnect the car battery overnight, or pull the radio fuse overnight, the presets come back after its put back together?
Old Feb 26, 2021 | 04:12 AM
blkatt's Avatar
Disconnecting the battery for a 1 minutes ought to do the trick. As for the radio fuse, I'll pull it, as it's the only thing I've yet to try. Thanks
Old Feb 26, 2021 | 06:32 AM
Goldpanda94's Avatar
I don't think I've been able to as well, but can I get an explanation on why it's a big deal if you can't? Like just cycle through the 5 or so of your presets you like? Not trying to be sarcastic or anything, just this has never popped into my head before lol. It's like trying to remove physical buttons 5-6 back when there were physical radio preset buttons cause you only want to use buttons 1-4.
Old Feb 26, 2021 | 06:36 AM
robtroxel's Avatar
That's normal behavior at least for both my 2016 and 2019 Platinum's Bose units
Old Feb 26, 2021 | 07:23 AM
blkatt's Avatar
Thanks robtroxel. It may be weird to me, but knowing it's the norm is all I need to know. .
Old Feb 26, 2021 | 04:28 PM
BrianShaw's Avatar
I just set the presets I’m not using to a station I hate... that way I know quickly which presets to avoid.
Jolyn
Jan 8, 2020 04:51 PM
jdunn1304
Dec 15, 2019 04:58 AM
MaximaDudes
Sep 20, 2004 01:10 PM
miky
Apr 13, 2004 09:54 AM
twankz
Feb 25, 2002 05:27 PM
