Melting Rubber Trim Around Roof
Old May 15, 2022 | 09:12 AM
dbeebs's Avatar
Hi all, not sure if anyone has addressed this in a previous thread but would appreciate any insights/suggestions to help.
I have a 2017 Maxima SL (with a sunroof), and the rubber trim around my roof is melting on both sides. I live in a hot climate and unfortunately have to my car in a parking lot with little shade throughout the day. I've attached a few pictures as well.
Old May 30, 2022 | 12:10 PM
BlackNYMax's Avatar
I am not much help with this but it doesn't surprise me with the crappy quality of the Maxima. I can easily see my '20 having this issue in the future.
A few weeks ago I saw some sorta recall for the Maximas back window as the glue might come off so they would replace the window under recall.... However my cars vin was not on the recall... Even tho that's not the back window, maybe your car is under the recall and that part is covered? Most likely not but worth a shot.
I absolutely love the Maxima but Nissan builds horrible quality cars...they assemble them like crap.
Old Jun 1, 2022 | 05:42 AM
IA_Hawkfan's Avatar
I recently purchased a '17 Maxima and both of my roof panels were melted like this too. Negotiated getting them replaced as part of the deal and according to the invoice those were about $400/ea. I agree with @BlackNYMax above that, while sharp lookers and decent performing, the build quality isn't quite what I'd expect from a Japanese automaker. The best line I've heard is that Nissan is the Chrysler of Japan.
Old Jun 18, 2022 | 06:40 PM
compyelc4's Avatar
Time to cut off the crud, tape off the bad area, and apply black hi-temp silicone adhesive. You can actually smooth out wet silicone adhesive with some water and a butter knife or similar. The wet tool prevents the silicone from sticking to the tool.
Old Jun 19, 2022 | 05:05 AM
robtroxel's Avatar
Great idea! Thanks
Old Dec 26, 2022 | 05:48 PM
japonicadunbar's Avatar
Check out this thread...
I'm having the same issue with my 2016 SL in the same exact spot. Check out this thread for some solutions. I haven't tried any yet though...
https://maxima.org/forums/7th-genera...bber-pics.html
Old Dec 27, 2022 | 03:04 PM
Maxcar's Avatar
I had the same problem this summer due to the extreme heat. J B weld plastic bonder worked very well. After mixed, I applied it and it created a hard protective outer shell on the trim. I them use model black paint to match the color. My only issue is i used the stick applicator JB weld provided so when you get up close it not smooth. I would recommend using a model paint brush.
I will take pics and upload
Old Dec 29, 2022 | 07:46 PM
Maxcar's Avatar
Here is a link to other posts about this topic
Old Apr 30, 2023 | 06:35 AM
Said's Avatar
Hi
Hopefully you solved the issue, I have same problem of the sunroof rubber, I'll be appreciated if you could help me to get the rubber kit, Please send me on my email: xx099009xx@gmail.com
Old Apr 30, 2023 | 03:28 PM
FattiesGoneWild's Avatar
Renault quality sprinkled in which is hot poo!
Old Jan 22, 2025 | 01:22 AM
RobMalone's Avatar
I’ve had a similar issue with the rubber trim around my roof melting on a car I used to own. I live in a pretty hot climate as well, and I found that the heat really took a toll on the trim over time. One thing I learned was that rubber compression molding can sometimes help with the durability of the trim, especially when exposed to harsh sunlight. I didn’t go that route initially, but after a few months of dealing with it, I started looking into options for more heat-resistant materials. For now, I’d suggest looking into a good quality trim repair kit or perhaps replacing the rubber with a more durable option.
sivilyar
Jan 13, 2023 04:48 AM
seanwreilly
Sep 13, 2021 06:41 PM
rbaker100
Oct 15, 2015 09:23 AM
GRAMPS54
38
Jan 27, 2015 09:22 PM
Gollum67
Feb 26, 2009 09:28 AM
