Electrical issue update new ac issue
Old Jul 2, 2022 | 12:45 PM
2016_maxima_sr's Avatar
So I figured out my electrical issue, although the alternator was testing good. there was a bad diode that would stop working once it got hot. that’s why it was still testing as being good. Then while replacing the alternator the ac line going to the condenser got nicked. it completely emptied the lines, so I ordered a replacement line installed it. Then recharged it till it was in the green. the ac was working fantastic for the first day. then it started blowing hot air I thought maybe it was still low on Freon. So I hooked up the recharge bottle and it was saying that the system was way over charged. Also the compressor isn’t kicking on so I’m not sure if it’s actually over charged or if it’s still low (why the compressor won’t kick on) does anyone know if the compressor won’t kick on if it’s low on Freon? Should I ignore the system over charged and try and add more Freon?
Old Jul 2, 2022 | 01:26 PM
Originally Posted by 2016_maxima_sr
So I figured out my electrical issue, although the alternator was testing good. there was a bad diode that would stop working once it got hot. that’s why it was still testing as being good l, but while replacing the alternator the ac line going to the condenser got nicked. it emptied the lines, so ordered a replacement line installed it and the ac was working fantastic for the first day. then it started blowing hot air and it was saying over charged but my compressor isn’t kicking on anyone know why?
Not enough freon.
Old Jul 2, 2022 | 06:50 PM
Not enough freon.
But after installing the line I hooked up a new bottle of Freon and recharged it till it was in the green and it worked great all day then I got home turned the car off for the night ext morning it was blowing hot and compressor wouldn’t kick on so I thought it was it was low on Freon so I hooked the bottle back up to the line and it was showing as being way over charged (but idk if it was actually over charged or if it was the compressor wasn’t kicking on) it’s currently saying overcharged should I try to add more Freon and see if that makes the compressor kick on?
Old Jul 3, 2022 | 05:36 AM
robtroxel's Avatar
The best thing to do here is to have the system purged and recharged by a pro. There could be too much of a charge which is as bad as not enough freon. There is a chance your system was contaminated after the pipe was nicked in which case a receiver/dryer might need replacing. (A receiver drier is found in AC systems that have thermal expansion valves. It's typical in foreign cars).
Thanks for letting us know the alternator outcome.
Old Jul 3, 2022 | 07:25 AM
compyelc4's Avatar
You can't just add freon to an empty system. The system must be purged of all air and then refilled. Best to have this done at a shop that has the equipment. Right now your "overcharge" probably consists of air and freon, both adding to too high a total pressure.
Old Jul 3, 2022 | 02:36 PM
+1
+1
Let a Pro handle this. AC work isn't as easy as it seems. For $99, a reputable repair shop should be able to purge and recharge as needed.
Old Oct 2, 2024 | 05:05 PM
premon123's Avatar
My Air conditioning
Hi guys I’m new here , I’ve been have a problem after the ac place replace condenser and compressor, the ac took a long time to drive for the ac to get cold , I don’t why cause I have to drive about 15 to 25 minutes , keep turn on and off the ac to get cold and then when it gets cold it’s ice .any idea?
I35GEEK
Aug 9, 2022 07:31 PM
Pnjboyzz
Jun 11, 2020 01:28 AM
acw
Jun 30, 2015 01:50 PM
acw
Apr 30, 2015 10:35 PM
deezo
Jul 14, 2008 09:26 AM
