Want a 2019 or newer maxima
Old Dec 20, 2022 | 08:30 AM
Hani's Avatar
Can anyone recommend which year of maxima to buy? I want a 2019 or newer.
Old Dec 20, 2022 | 08:55 AM
Goldpanda94's Avatar
If you want a 2019 or newer, they're literally all the same car. Only difference is which trim you'll get and that's based on what features you want.
They got rid of the SL trim so I think either SV or SR (the sportier one) is the best deal.
If you want to save a little money and like the pre-facelift better, the 2018 would be the best IMO has AA/Carplay and the engine/powertrain are all the same basically going forward.
Old Dec 21, 2022 | 07:14 AM
robtroxel's Avatar
2019 or newer gets rid of the memory card on the radio, car has a refined look with the latest headlight taillight combo and led turn signals. Go for a Platinum. Much more std equipment. Like heated steering wheel
Old Dec 21, 2022 | 09:34 AM
Turbobink's Avatar
I’d encourage you to pursue a 2000 or older …
Old Dec 23, 2022 | 03:41 AM
Hani's Avatar
I have 2002 se. Still runs very well and i take good care of it just want something newer than what i got. I teally like the 2019 and newer versions
Old Dec 23, 2022 | 04:25 AM
wild willy2's Avatar
One of the last of the years when they were a true sports sedan. After 03......went down hill in my opinion. Then the introduction of the CVT....forget it.
Old Dec 23, 2022 | 07:36 PM
Hani's Avatar
I hear you. It's a hard car to get rid of. I keep saying I'll get a new one when it dies but it will not die. Has 300,00kms on it and has no real issues
Old Dec 24, 2022 | 04:57 AM
It's nice to not have to worry about your trans shiating the bed
Old Dec 24, 2022 | 05:38 PM
Hani's Avatar
I definitely hear you there. The manual transmission is a blessing. I hear the 8th gen maxima has a reliable transmission because nissan worked out lots if the kinks. Hopefully when/if I pull the trigger I'll I'll able to maintaining properly
Old Jan 1, 2023 | 07:40 AM
lindros2's Avatar
I can confirm that the navigation hasn’t changed one bit since 2019 - even though the firmware versions differ, they have all the same bugs.
Nissan is decades behind others.
Old Jan 1, 2023 | 02:08 PM
Hani's Avatar
thanks for the reply I'll definitely keep that in mind
Old Jan 12, 2023 | 06:35 PM
CMax03's Avatar
I still have the 2003 with 258K now...Valve stem seal leaking and I'm going to pull the motor and take car of it. Pull the heads maybe clean up the ports a little throw in larger valves and a cam, fortify the engine with ARP Rod bolts, main Studs, and head studs and reinstall it!
Old Jan 12, 2023 | 06:36 PM
CMax03's Avatar
I'm actually sitting back looking at the 7th and 8th gen Maxima age and it's not looking too good!
Old Jan 13, 2023 | 06:26 AM
Hani's Avatar
Nice work maintaining the 03. What kind of problems are you seeing with the 7th and 8th generations?
Stariq21
Apr 15, 2016 07:11 PM
aliti19
Aug 8, 2005 08:25 AM
maxfanfromohio
41
Mar 10, 2003 08:19 PM
