Cigarette/power outlet not working
Old Apr 6, 2023 | 04:16 PM
Noahdomani's Avatar
I've got no power in the outlet. I checked the fuse block and have power through the fuse. Used a multimeter to check the connect at the power outlet, nothing. Can someone point me at a diagram that will show me which wires from the fuse box go to the outlet?
Old May 5, 2023 | 05:25 PM
Noahdomani's Avatar
No answer but felt dumb. Pulled the console, followed the wire and somehow the connector under radio must have rattled loose
Old May 6, 2023 | 05:45 AM
robtroxel's Avatar
Thanks for the follow up report. How hard was it to check this connection? I would have guessed a fuse 1st. but every now and then it pays to go for the obvious. Good luck with your Maxima
Old May 6, 2023 | 06:14 AM
Noahdomani's Avatar
It was fairly easy, remove the clip from the shift ****, pull up the console, and follow the wire, it's not to far in and you can feel the clip. I thought it was a fuse at first or a broken power socket. Then figured the last owner hooked something up and screwed it up. Nope. It just talked loose. Now trying to figure out what's wrong with the damn USB port giving me errors. Arg. But love this car.
TomRS
May 19, 2016 04:21 PM
2004 Smoke
Nov 25, 2004 11:50 AM
SuperFishstick
Oct 21, 2002 06:26 PM
97MaxGurl
Jul 20, 2002 09:41 AM
aggroman13
May 1, 2002 05:19 AM
